Register to reply
Loudspeaker cone problem
by saltrock
Tags: cone, loudspeaker
Share this thread:
saltrock
#1
Dec13-04, 07:16 AM
P: 68
AA loud speaker cone is connected to a AC signal genetator.When the frequency of the signal genetor is alterned the amplitude of the cone changes.why?
My working:
As the frequency increases the amplitude decreases because there is less change in the magnetic flux and vice versia....I am a bit confused about the relationship between the amplitude and frequency...
can you please give me some scientific evidence to lead me in the correct path.Any help would highly be appriciated
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Andrew Mason
#2
Dec13-04, 06:41 PM
Sci Advisor
HW Helper
P: 6,654
Quote Quote by saltrock
In a loud speaker, current passes through a coil. As the frequency increases, the inductive reactance increases, which opposes current flow (when frequency decreases, reactance decreases, thereby reducing opposition to current). This change in current would have a proportionate change on the magnetic force driving the cone, thereby chaning the amplitude (distance the cone moves per vibration period (T=1/f)).
AM
Loren Booda
#3
Dec13-04, 11:06 PM
Loren Booda's Avatar
P: 3,408
Also, mechanical resonances, often represented by Bessel functions, vary (nonlinearly?) the efficiency of the cone surface with repect to frequency.
pack_rat2
#4
Dec13-04, 11:16 PM
P: 183
Quote Quote by Andrew Mason
In a loud speaker, current passes through a coil. As the frequency increases, the inductive reactance increases...
That's true to a slight extent, but isn't sufficient to explain the fairly large decrease in cone displacement vs freq. Speakers normally have pretty low reactance at audio frequencies. The main cause of the reduced amplitude is the mass of the system. The mass must be accelerated by the force from the magntic field produced by the coil. If that force changes more quickly, the cone is less able to follow it.
Register to reply
Related Discussions
Shock Wave Cone Problem Introductory Physics Homework 5
Depth of a cone rate problem (question about the equation I'm using) Calculus & Beyond Homework 1
Ice Cream Cone Problem Calculus & Beyond Homework 11
Sphere/cone volume problem Calculus & Beyond Homework 23
Related Rates Calculus Cone problem Calculus & Beyond Homework 6
