Why Are Giant Stars So Low in Density?
  • Context: Undergrad
  • Thread starter Thread starter triabva2003
    Density Stars
The discussion centers on the reasons why giant stars exhibit low density compared to main-sequence stars. It explores concepts related to stellar evolution, particularly the processes that lead to the expansion and structural changes in stars as they transition into the red giant phase.
  • Some participants suggest that giant stars have low density due to the burning of fuel and the bloating of outer layers, which occurs as gravity becomes less effective at maintaining compactness.
  • Others argue that while the cores of giant stars may be dense, the average density is lower than that of main-sequence stars, which still undergo hydrogen fusion and maintain compact outer layers.
  • A participant describes the internal structure of main-sequence stars as being uniform, while giant stars have a core and an envelope that behave differently, leading to lower densities in the outer regions.
  • One participant outlines a sequence of events in stellar evolution that leads to the red giant stage, emphasizing the role of both core and shell fusion in the expansion process.
  • Another participant challenges the notion that less gravity is the primary factor, stating that the core becomes superheated, which affects the outer layers and maintains hydrostatic equilibrium until temperature changes disrupt this balance.
  • Some participants clarify that during the final stages of a giant star's life, the core may not contribute to fusion, and the outer helium shell becomes responsible for the expansion and eventual loss of outer layers.
Participants express differing views on the mechanisms behind the low density of giant stars, with some attributing it to the effects of gravity and fuel consumption, while others emphasize the roles of core temperature and shell fusion. The discussion remains unresolved, with multiple competing explanations presented.
Limitations in the discussion include varying assumptions about the roles of gravity, core temperature, and fusion processes in determining the density of giant stars. The complexity of stellar evolution and the interplay between different layers of a star are acknowledged but not fully resolved.
triabva2003
Why giant stars are so low in density?
Astronomy news on Phys.org
By the time they become giants they have burnt up a lot of their fuel and their outer layers have bloated due to less gravity. It doesn't mean that their cores aren't very dense though. It just means their average density is lower than main sequence stars which are still fusing hydrogen and have enough gravity to keep their outer layers compact..
Here's one way you can think about it. Main-sequence stars are considered dwarfs, so giant stars are giant in relation to main-sequence stars. Main-sequence stars have an internal structure that is sort of "all one thing"--they inject heat essentially at the center and the whole rest of the star lives under the conditions of needing to pass outward that heat. So they have a simple structure that can be simply described by the mass of the star, and the size is controlled by the average gravitational potential energy. But a giant star has fusion occurring in shells that are around the outside of the core, so the entire outside of the star is passing outward energy that the core is not. This means giant stars are basically not "all one thing", they are fundamentally made of a core plus an envelope, which are carrying different amounts of energy and behave differently. What happens is the need for the outer region (the "envelope") to carry more energy causes it to puff out to much lower densities than it would have otherwise, and this is what makes the star attain a "giant" radius.
In harmony with what has already been said above.
Here is the sequence that leads a sun-like star to the Red Giant stage.
1. Star fuses Hydrogen to helium in its core
2, Hydrogen into Helium fusion in Core ceases
3. Star compresses
4.. Helium into oxygen and carbon fusion begins in core
5. A layer of Hydrogen that surrounds the core begins fusing Hydrogen to Helium
6. Both types, core and shell fusion combine and cause the star to grow enormous as their combined outward thrust overpowers gravity.
7. Helium fusion at the core stops-outward pressure decreases
8. Gravity causes red giant star to collapse and shrink
9. Insufficient mass to fuse oxygen and Carbon = inert fusionless core
10. Helium shell around inert core begins fusion causing utward pressure and restoring
the star to red giant size.
11. Insufficient gravity cannot stop the outward 100,000 mpr expansion. Star lses uter layers leaving a fusionless core behind.
12. That inert, fusionless core is called a white dwarf.
White Dwarf
http://www.eg.bucknell.edu/physics/astronomy/as102-spr00/web_pages/web8.html
It has nothing to do with less gravity. The core becomes super heated in ancient stars - which means more pressure on the outer layers. Stars are in a continuos state of hydrostatic equilibrium - until the core temperature becomes too hot or cool to remain in gravitational balance.
No that isn't the way it works throughout the whole process. Neither does the expansion depend only on a superheated core. As explained in my second post, the shells surrounding the core contribute significantly by becoming superheated by pressure and NOT by core fusion itself.
At one point, both core and shell are fusing different elements and contributing to the sustenance of the Red Giant stage.
However, the last stage has the core contributing NOTHING. The helium shell alone then becomes responsible for the runaway expansion in which the star loses all its outer layer leaving behind a white dwarf.
It can't be caused by a superheated core at that stage because the core by that time isn't fusing anything.
Here is the sequence that leads a sun-like star to Red Giant stage.
3. Star compresses
5. A layer of Hydrogen that surrounds the core now begins fusing Hydrogen to Helium
9. Insufficient mass to fuse oxygen and Carbon into heavier element = inert fusionless core
10. Helium shell around inert core begins fusion causing outward pressure and restoring
11. There is insufficient gravity to stop the outward 100,000 mph expansion. Star loses outer layers leaving a fusionless core behind.
12. That inert fusionless core is called a white dwarf.
The core's gravity is insufficient to prevent that last stage leading to what is called a planetary nebula. Surrounded by this nebula is the star's former inert core now called a white dwarf star. Such a star is prevented from further collapse by electron resistance to additional gravitational compression. More massive stars that can overcome this resistance wind up as neutron stars or black holes.
White Dwarf
  • · Replies 16 ·
  • · Replies 32 ·
  • · Replies 49 ·
