| New Reply |
Know a good way to estimate fuel flow for a turboprop? |
Share Thread | Thread Tools |
| Jan9-12, 01:40 PM | #1 |
Hey Guys,
I need a rough estimate for how your fuel flow changes with altitude and mach number. I am trying to figure out this problem. If you are applying 1000 hp at sea level static with 100lb of fuel per hour. How much fuel (lb/h) would you need to provide to at 5000ft and a velocity of 0 ft/s. How much fuel would you need to supply at sea level going mach .3. And finally how much fuel would you need to supply at mach .3 and 5000 feet altitude. Thanks, Aeroguy |
| New Reply |
| Thread Tools | |
Similar Threads for: Know a good way to estimate fuel flow for a turboprop?
| what is Motive Flow in an Aircraft Fuel System? | Aerospace Engineering | 1 | ||
| Gulf Oil Spill Velocimetry-Based Flow Rate Estimate | Mechanical Engineering | 54 | ||
| Comparing turboprop and turbofan | Aerospace Engineering | 2 | ||
| Cost estimate of Hydrogen Fuel Cells versus Gasoline | Engineering Systems & Design | 2 | ||
| Estimate for the liquid flow-rate into a gas scrubber | Materials & Chemical Engineering | 2 | ||
