Maximum bending stress in wooden beam
The discussion revolves around calculating the maximum bending stress in a wooden beam that is intended to support part of a ceiling. Participants explore the application of bending moment equations and the effects of various loads, including the beam's self-weight, on the beam's structural integrity. The context includes homework-related problem-solving in mechanics of materials.
  • Homework-related
  • One participant presents the problem of determining the maximum bending stress in a simply supported beam under multiple loads, including its self-weight.
  • Another participant suggests calculating the bending moment at midspan to find the bending stress.
  • There is a discussion about the correct application of bending moment equations and the need to consider the beam's self-weight in calculations.
  • Participants express uncertainty about whether different bending moment equations yield consistent results when evaluated at the same point.
  • One participant calculates the bending stress using the formula σ = Mc / I and presents values that suggest the beam may not support the loads.
  • Corrections are made regarding the notation and units used in calculations, emphasizing the importance of precision in mathematical expressions.
  • There is a discussion about potential errors in arithmetic and the need for careful checking of calculations.
Participants generally agree on the approach to calculating bending stress but express differing views on the accuracy of specific calculations and the interpretation of the bending moment equations. The discussion remains unresolved regarding the final assessment of the beam's ability to support the loads.
Participants note potential limitations in their calculations, including the handling of distributed loads and the need for consistent application of bending moment equations across different sections of the beam.
mh1985
A timber beam will be used to support part of the ceiling of a house. It is
going to be attached to the walls as a simply supported beam, Figure 6.
If three forces are applied to it and considering the weight of the beam as a
uniformly distributed load of magnitude w = ρAg (which you will need to
calculate and include in the FBD), determine the maximum bending stress
due to these loads.
The properties of the wooden beam are ρ = 470
kg/m^3 , σMax = 10 MPa. Can the beam support these loads or will it fail?
σ = y* M / I
I'm struggling to get the Moment about the axis, because of the other loads, not sure if I'm supposed to section the beam or not.
Weight of uniformly distributed load:
Not sure about this, but going by what the question gives w = ρAg
470 kg/m^3 x 0.165 m x 0.250 m x 9.81 = 190.191375 N /m
So far I have:
I = 1/12 * bh^3 = 2.1484 * 10^-4 m^4
The reactions at the bases :
I took the distributed load and put it as a resultant
ƩM @A = (RB*5 m) -(10 kN *1 m) -(5.95096 kN*2.5 m) - (10 kN * 4 m)
RB = 64.8774/5 = 12.97548 kN
Now I'm stuck as to what the next step is...
mh1985: Hint 1: Would you need to compute bending moment at midspan? And then compute bending stress at midspan?
would that be at x = 2.5 m?
Yes.
nvn said:
Yes.
Not sure if this is right but:
Bending moment at x = 2.5,
(12.98 * 2.5) - (10 * 1.5) + (10 * 1.5) - (12.98 * 2.5) = 0 ??
Again, don't know if I need to do this but I have sectioned the beam and done the bending moment diagrams, which has given me the equation:
12.98x - 0.0951x^2, for x= 2.5 this is 31.855625 kNm and 12.98x - 0.0951x^2 + 10 -10x, for x = 2.5 this is 16.855625 kNm
I don't know if this is the right way to do it, also not sure how to get the bending stress at midspan?
mh1985: That currently looks correct. Your equation for bending stress is in post 1.
Thanks.
how do I include the weight of the beam in this though?
Which value for M do I use in the bending stress equation?
mh1985: The beam self weight is already included in your moment calculation. You included it in your calculation. Use the moment you computed in post 5.
but aren't there two depending on which side of 2.5 x is? ie. 31.855625 kNm and 18.855625 kNm
EDIT:
I have done tau_max = Mc / I for both:
(31.85 x 10^3 N x 0.125 m)/ 2.1484 x 10^-4 m = 18.53 MPa
(18.856 x 10^3 N x 0.125 m) / 2.1484 x 10^-4m = 10.97 Mpa
So the beam cannot support these loads? I'm not sure I've answered the question properly...
quote but aren't there two depending on which side of 2.5 x is? ie. 31.855625 kNm and 18.855625 kNm end quote
There is obviously an error because the bending moment to the right of centre should be exactly the same as the bending moment to the left. I suggest (1) that there is a central 5 kN load in your diagram that is not the self weight of the beam, and which you ignored when getting the reactions. (2) To lump the distributed load at the centre is Ok for getting reactions but totally wrong when calculating bending moments.
mh1985: In post 6, when I said, "That currently looks correct," I was referring to 16.84 kN*m. And I forgot to say, your equation for the 31.86 kN*m in post 5 is not applicable beyond x = 1.0 m; therefore, ignore your second equation in post 5.
I do not know why you mistyped your moment in post 9, when it was correct in post 6. Try again. Also, the stress should not be called tau_max in post 9; it should be called sigma_max.
(1) By the way, the unit symbol for megapascal is spelled MPa, not Mpa. Lowercase p means pico.
(2) Two units (or quantities) multiplied together must be separated by an asterisk, middle dot (·), space, or parentheses. E.g., kN*m, not kNm.
(3) Generally always maintain at least four significant digits throughout all your intermediate calculations, then round only the final answer to three significant digits, unless the first significant digit of the final answer is 1, in which case round the final answer to four significant digits.​
many thanks for pointing those out!
With regard to the moment being different depending on which equation I used, what about when I use the one for 2.5< x <4, shouldn't this give the same value as the equation for 1 < x<2.5 provided I used x = 2.5 ?
I've redone it and come up with this,
σ (max) = Mc / I = [(16.855625 kN*m) * (0.125 m)]/ 2.1484*10^-4m = 9.807 MPa
mh1985: Nice work. Your answer is correct. See item 3 in post 11. Somewhere along the way, you may have rounded a number too much (?). If you do not, I think you would end up with 9.80 MPa, whereas you currently ended up with 9.81 MPa.
mh1985 said:
... shouldn't this give the same value as the equation for 1 < x < 2.5, provided I used x = 2.5?
Yes.
Yes.
Thanks, well at least I have the right answer.
I think I'm doing something wrong with the bending moment equations in that case because I get something different for each one:
for 1 < x < 2.5
M = 12.98x - 0.0951x^2 - 10(x-1)
x = 2.5, M = 16.86 kN*m
for 2.5 < x < 4
M = 12.98x - 0.0951x^2 - 10(x-1) - 5(x-2.5)
x = 2.5, M = 26.86 kN*m
mh1985: You did not check your arithmetic yet. Try computing M a few more times, and check your arithmetic. If you are having trouble with your calculator, try an HP calculator (probably preferably HP 35s[/color]), and use RPN (reverse Polish notation).
I have just seen it now, I was expanding the brackets out before, but if I don't do that, on the 2nd equation where we have
5(x-2.5) for x=2.5, this is 5(2.5-2.5) = 0...must've made an error when expanding them out. thanks!
where have you used ρ=470?
  • · Replies 22 ·
  • · Replies 17 ·
