Solve Pressure Problem for Scuba Diver: Find Duration Underwater
  • Thread starter Thread starter myogi
    Fluids Pressure
The scuba diver's tank has a volume of 0.015 cubic meters filled with air at an absolute pressure of 2.02e7 Pa. At a depth of 30.0 meters, the diver can stay underwater for approximately 3.28 minutes, assuming a constant air consumption rate of 0.03 cubic meters per minute. The pressure at this depth is calculated using the formula P = ρgh, resulting in a pressure of 299,400 Pa. It is crucial to account for the pressure change when calculating the available air volume and consumption time.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of pressure calculations in fluids (P = ρgh)
  • Basic scuba diving principles, including air consumption rates
  • Familiarity with unit conversions (cubic meters to liters)
  • Learn about pressure dynamics in scuba diving environments
  • Study the Ideal Gas Law applications in real-world scenarios
  • Research safe ascent rates and decompression procedures for divers
  • Explore scuba tank specifications and air consumption calculations
Scuba divers, diving instructors, and safety personnel involved in underwater activities who need to understand air consumption and pressure effects at depth.
myogi
Ok, I got this scuba diver and he has a tank that is 0.015 meters cubed and filled with compressed air at an absolute pressure of 2.02e7 Pa. Assuming air is consumed at a rate of 0.03 meters cubed per minute and the temperature is constant, how long can this diver stay under water at a depth of 30.0 meters? Assuming the density of the water is 1025 kilograms per meter cubed
I found the pressure at 30 ft. below, but I didn't really know what to do with it. Help??
myogi said:
Ok, I got this scuba diver and he has a tank that is 0.015 meters cubed and filled with compressed air at an absolute pressure of 2.02e7 Pa. Assuming air is consumed at a rate of 0.03 meters cubed per minute and the temperature is constant, how long can this diver stay under water at a depth of 30.0 meters? Assuming the density of the water is 1025 kilograms per meter cubed.
You will need to find the pressure at a depth of 30 metres.
I assume that the .03 m^3/min. is the volume rate of air at a depth of 30 m. So work out how much volume the tank contains when let out with the ambient pressure at 30 m. ([itex]V \propto 1/P[/itex]). With that total volume, work out the consumption time from the consumption rate.
Keep in mind, if he stays that that long at 30 m. he will die. He needs some air to get down to 30m and some air to get back. He has to come up gradually.
AM
To solve this problem, we can use the ideal gas law which states that pressure, volume, and temperature are related by the equation PV=nRT, where P is the pressure, V is the volume, n is the number of moles of gas, R is the gas constant, and T is the temperature.
First, we need to convert the tank volume from 0.015 meters cubed to liters by multiplying it by 1000. This gives us a volume of 15 liters.
Next, we need to find the number of moles of gas in the tank. We can do this by using the ideal gas law and solving for n. Since we know the pressure, volume, and temperature are constant, we can set up the following equation:
(2.02e7 Pa)(15 L) = n(8.31 J/mol*K)(298 K)
Solving for n gives us a value of approximately 98.4 moles of gas in the tank.
Now, we can use this information to find the amount of time the diver can stay underwater. We know that the diver is consuming 0.03 meters cubed of air per minute, which is equal to 30 liters.
To find the duration, we can use the formula:
Duration = (Number of moles of gas in tank) / (Rate of consumption of gas)
Plugging in our values, we get:
Duration = (98.4 moles) / (30 L/min) = 3.28 minutes
Therefore, the diver can stay underwater for approximately 3.28 minutes at a depth of 30.0 meters using the given tank and assuming a constant temperature.
However, we also need to take into account the density of the water. This means that the pressure at a depth of 30.0 meters will not be the same as the pressure at the surface. Using the equation P = ρgh, where P is pressure, ρ is density, g is the acceleration due to gravity, and h is the depth, we can find the pressure at a depth of 30.0 meters.
Plugging in the values, we get:
P = (1025 kg/m^3)(9.8 m/s^2)(30.0 m) = 299400 Pa
This is the actual pressure at a depth of 30.0 meters, which is significantly lower than the absolute
  • · Replies 18 ·
11K
10K
