Solving a Tower Height with Cosine Law
The problem involves determining the height of a tower based on angles of elevation observed from two different distances. The angles of elevation are 10 degrees and 20 degrees, with the second observer positioned 100 meters closer to the tower.
  • Mixed
  • Participants discuss the formation of triangles based on the angles of elevation and the distance between the observers and the tower. There are attempts to apply both tangent functions and the cosine law to find the height of the tower. Some participants express uncertainty about how to effectively use the cosine law in this context.
There is an ongoing exploration of different methods to approach the problem. Some participants suggest that while the cosine law could be applied, it may not be the most straightforward method. Others acknowledge the potential for simpler solutions using trigonometric functions like sine and tangent.
Participants note that the problem is framed within a unit focused on the cosine law, which may influence their approach despite recognizing alternative methods. There is a shared understanding that the angles and distances involved are critical to the solution.
uranium_235
Question:
A man is looking at the top of a tower. The angle of elevation to the top of the tower is 10 degrees. 100m closer to the tower, a man has an angle of elevation to the top of the tower of 20 degrees, how tall is the tower?
My Problem:
I can solve this ver easily by recognizing that an isosceles triangle is formed when you draw the line of sight of the closer man, and since one of the sides of the isosceles is 100m the other side is as well, then I solve the smaller right triangle with tangents and get an answer approximately equal to 36m. But, this unit is on Cosine law, and I don't see how I can solve this with cosine law. Help?
uranium_235 said:
Question:
My Problem:
Yes you figured out well there should be an isosceles triangle somewhere.The important thing is to apply the "cosine law" in that isosceceles triangle to find the only side u don't know.That side is actually the hypotenuse in a rectangular triangle that has the tower as one of the sides.Then u just have to apply the definition of the function "sine" and u'll "home safe".
Hi uranium_235,
You're right, this prob is much easier to solve your way, however i got x = 100*sin(20) = 34.2, not quite 36. The law of cosines is good if you know 2 sides and 1 certain angle. You could apply this law by finding the length of the bottom (along the ground) of the right triangle (by the tower) and then: a^2 = b^2 + c^2 - 2bc*cos(A), where A = 20 degrees, b = length of bottom, and c = 100m.
Herr Schlauberger's right.
And the cosine law is a little bit of a convoluted route to take to the solution. A better question would have been how far the top of the tower was from the further man, a problem where the cosine law would be the most efficient solution.
