Car Runs Out of Gas: Calculate Speed After Coasting Down Hill
  • Thread starter Thread starter tigerseye
    Car Gas
The discussion focuses on calculating the speed of a 1500 kg car after it coasts down a hill, starting with an initial speed of 10.0 m/s. The correct approach involves applying the conservation of energy principle, specifically using the equation 1/2*m*(v_1)^2 + mgh_1 = 1/2*m*(v_2)^2 + mgh_2. Key factors include the height of the hill and gravitational acceleration (g). Accurate calculations require consistent units and careful consideration of potential energy signs.
  • Understanding of conservation of energy principles
  • Familiarity with kinetic and potential energy equations
  • Knowledge of gravitational acceleration (g = 9.81 m/s²)
  • Ability to perform unit conversions and dimensional analysis
  • Calculate potential energy using height and mass for different hill heights
  • Learn about energy conservation in mechanical systems
  • Explore kinematic equations related to motion on inclined planes
  • Practice solving similar physics problems involving energy transformations
Students studying physics, educators teaching energy conservation, and anyone interested in solving real-world mechanics problems involving motion and energy.
tigerseye
A 1500 kg car is approaching a hill shown in the diagram at 10.0 m/s when it suddenly runs out of gas. Assuming the car makes it to the top by coasting, what is the car's speed after coasting down the other side?
I tried using 1/2*m*(v_1)^2+mgh_1= 1/2*m*(v_2)^2+mgh_2 but didn't get the right answer.
Well, this looks like a straight conservation of energy problem, with a little kinematics, maybe. The speed is affected by how fast the car is moving on top.. figure out how much energy the car has on top of the hill... then try conservation of energy again.
The equation you used, 1/2*m*(v_1)^2+mgh_1= 1/2*m*(v_2)^2+mgh_2, is the correct equation to use in this scenario. However, there may be a mistake in your calculations or some information missing that is causing you to not get the correct answer. To solve this problem, you will need to use the conservation of energy principle, which states that energy cannot be created or destroyed, only transferred from one form to another. In this case, the initial kinetic energy of the car is converted into potential energy as it goes up the hill, and then back into kinetic energy as it goes down the other side.
To solve for the final speed, you will need to know the height of the hill (h_1 and h_2) and the gravitational acceleration (g). You also need to make sure that the units for all the variables are consistent (e.g. if height is in meters, make sure g is in m/s^2). Once you have all the necessary information, plug in the values into the equation and solve for v_2. Remember to use the correct signs for potential energy (positive when going up, negative when going down) and to take into account the initial velocity of the car (10.0 m/s).
If you are still having trouble getting the correct answer, double check your calculations and make sure you are using the correct values for the variables. It may also be helpful to draw a diagram and label all the given information to visualize the problem better. Keep in mind that the final speed after coasting down the other side will depend on the initial speed, the height of the hill, and the mass of the car.
14K
18K
  • · Replies 17 ·
