| View Poll Results: Time: | |||
| A-series (Presentism, Growing Block Theory, Moving Spotlight Theory, etc.) |
13 | 44.83% |
| B-series (Eternalism, Block Universe, etc.) |
10 | 34.48% |
| Undecided |
3 | 10.34% |
| Other (Please Explain) |
3 | 10.34% |
| Voters: 29. You may not vote on this poll | |||
| Thread Closed |
Time: A-series or B-series? |
Share Thread | Thread Tools |
| Mar26-12, 07:25 AM | #35 |
Time: A-series or B-series?Our perception of a "flow of time" in this model is like looking out of a train window and seeing the countryside flow past, but in fact the landscape ahead is already set in stone and the flow is an illusion. "Change" is the sequential variation of the intersection of the plane with the worms of our lifelines. |
| Mar26-12, 08:09 AM | #36 |
| Apr11-12, 08:28 AM | #37 |
Just a question about the A-theory of time, and presentism in particular: I thought the concept was fairly well understood, but in a discussion on this site, it appears that it might not be that well understood.
I'm just looking for a fairly concise explanation of presentism. I would say that it is the idea that there is a single, universal present moment, common to all observers. I would see this as being incompatible with the relativity of simultaneity, which I think leads to the B-theory of time, and the idea that there is no single, universal present moment, but that the present moment is relative to each individual (although it can be shared). I was also under the impression that Lorentz Ether Theory incorporates presentism, I'm just wondering if anyone knows if this is true or not? p.s. I don't want to get into a philosophical discussion about the accuracy, or otherwise of LET, I'm just wondering if it incorporates the concept of presentism [as I outlined above] |
| Apr11-12, 12:29 PM | #38 |
http://en.wikipedia.org/wiki/Present...osophy_of_time) This is more comprehensive and introduces relativity too: http://plato.stanford.edu/entries/temporal-parts/ "If STR thereby rules out presentism, and if endurantism requires presentism in order to explain change (see section 3), then STR rules out endurantism: things have temporal parts. But not all endurantists agree that they must be presentists, and not all presentists agree that their view is undermined by STR." http://www.iep.utm.edu/time/#H1 This is a paper on B-theory by Pruss which might also give you some background: http://www9.georgetown.edu/faculty/a...s/BTheory.html |
| Apr11-12, 03:32 PM | #39 |
The only person that I can recall that uses LET to support presentism is William Lane Craig, who opts for a "neo-lorentzian" interpretation (and he is the only person to do so apparently according to a paper I've read a while ago). I am not a fan of his work though, but you can look him up if you want. |
| Apr12-12, 02:07 AM | #40 |
That would be my own general understanding also, but with the added qualification that there is only one present, common to all observers. LET appears to be founded on Newtonian assumptions about space and time, which was inherently presentism-friendly; while Einsteinian relativity doesn't appear to be presentism-friendly. I don't mean to be facetious, but saying that SR doesn't necessarily rule out presentism, assuming that you can assume an undetectable present that is not the same as an ether theory, sounds a bit like saying, it doesn't rule out presentism as long as you can find an undetectable present that is compatible with SR. If the above description of RoS is accurate, and SR incorporates it, then it is incompatible with the definition of presentism above. |
| Apr13-12, 08:11 AM | #41 |
However, SR also has a geometric interpretation (often attributed to Minkowski rather than Einstein) which is also carried forward to GR. That interpretation describes a 4-dimensional hypervolume we call spacetime. Within that, there is nothing intrinsic which uniquely distinguishes the basis vector of time. Since a surface of uniform time (isotemporal?) would be perpendicular the time vector, it too cannot be physically meaningful, thus the geometric interpretation of SR which is fundamental to GR supports the B-theory (and 4-dimensionalism in particular). The effect known as "relativity of simultaneity" is irrelevant from the philosophical perspective. |
| Apr15-12, 01:22 PM | #42 |
| Apr15-12, 04:00 PM | #43 |
None of your comment appears to relate to foliation of spacetime. |
| Apr18-12, 12:43 AM | #44 |
Are the A- and B-theories of time linked to any scientific theories?
The impression that I get is that B-theory is linked to Einsteinian relativity, or that it is compatible with it, while A-theory is not compatible with Einsteinian relativity. |
| Apr18-12, 12:56 AM | #45 |
EDIT: I don't want to derail this thread into a discussion about RoS, so I will just reply to this one post and leave it at that.
| Apr18-12, 06:34 AM | #46 |
"it can be plausibly argued that the theory [of relativity ] [..] has no bearing on whether there is such a phenomenon as absolute simultaneity." Consistent with that (and despite the fact that I don't believe in a literal "flow of time"), I will now vote A. A very hasty reading gives me the impression that I largely agree with Taggert, as I define time as being a measure of progress of physical processes - which implies change. PS however, I now see that Taggert claimed that A is wrong, despite the fact that he largely agreed with my thinking; and like him I also hold that time doesn't really exist. And I definitely disagree with B. Thus perhaps I should change my vote to "other"? |
| Apr18-12, 06:46 AM | #47 |
I now see that it's impossible to correct a vote; thus it's not a very good poll, regretfully. While I certainly disagree with B, I'm not sure that I fully agree with A.
| Apr18-12, 08:35 AM | #48 |
| Apr18-12, 10:27 AM | #49 |
![]() Still it gives a very rough indication about how participants think about time; it appears that there is no clear majority view! |
| Apr18-12, 12:42 PM | #50 |
It might be tomorrow, I have to go out soon. |
| Apr18-12, 03:09 PM | #51 |
| Thread Closed |
| Tags |
| a-series, b-series, time |
| Thread Tools | |
Similar Threads for: Time: A-series or B-series?
| check my solution to a power series/taylor series problem | Calculus & Beyond Homework | 2 | ||
| Calculus 2 - Infinite Series Question - Estimating Series with Positive Terms | Calculus & Beyond Homework | 5 | ||
| Taylor Series using Geometric Series and Power Series | Calculus & Beyond Homework | 5 | ||
| Exploiting Geometric Series with Power Series for Taylors Series | Calculus & Beyond Homework | 11 | ||
| Divergent Harmonic Series, Convergent P-Series (Cauchy sequences) | Calculus & Beyond Homework | 1 | ||
