Register to reply
Easy delta/epsilon proof of a multivariable limit
by pureza
Tags: limit definition
Share this thread:
pureza
#1
Jan18-12, 11:28 PM
P: 3
Hi,
I'm trying to wrap my head around epsilon/delta proofs for multivariable limits and it turns out I became stuck on an easy one!
The limit is:
[itex]\lim_{(x,y) \to (1,1)}\frac{xy}{x+y}[/itex]
Obviously, the result is [itex]1/2[/itex], but I'm unable to prove it!
Any hints?
Thank you!
Phys.Org News Partner Science news on Phys.org
'Smart material' chin strap harvests energy from chewing
King Richard III died painfully on battlefield
Capturing ancient Maya sites from both a rat's and a 'bat's eye view'
HallsofIvy
#2
Jan19-12, 09:02 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,682
Well, what have you done? I assume you want to prove that
"Given [itex]\epsilon> 0[/itex] there exist [itex]\delta> 0[/itex] such that if [itex]\sqrt{(x-1)^2+ (y-1)^2}<\delta[/itex] then
[tex]\sqrt{\frac{xy}{x+y}- 1}<\epsilon[/tex]"
pureza
#3
Jan19-12, 09:48 AM
P: 3
Actually I think I might have solved it:
I want to prove that
[tex]\left|\frac{xy}{x+y}- \frac{1}{2}\right|<\epsilon[/tex]
Now,
[tex]\left|\frac{xy}{x+y}- \frac{1}{2}\right|=\left|\frac{2xy-(x+y)}{2(x+y)}\right|=\left|\frac{xy + xy-x-y)}{2(x+y)}\right|=\left|\frac{x(y-1)+y(x-1)}{2(x+y)}\right|\leq\left|\frac{x(y-1)}{2(x+y)}\right|+\left|\frac{y(x-1)}{2(x+y)}\right|[/tex] by the triangle inequality.
Now, I know that since [itex]{(x,y) \to (1,1)}[/itex] I can make [itex]x[/itex] and [itex]y[/itex] positive so that [itex]\left|\frac{x}{x+y}\right|\leq1[/itex] and [itex]\left|\frac{y}{x+y}\right|\leq1[/itex]. [I'm no sure about this argument]
This way,
[tex]\left|\frac{x(y-1)}{2(x+y)}\right|+\left|\frac{y(x-1)}{2(x+y)}\right|\leq|y-1|+|x-1|[/tex]
But this is just a square with side 2 around the point [itex](x, y)[/itex]. This square is entirely contained by the circle with center [itex](x, y)[/itex] and radius [itex]\sqrt{2}[/itex].
So, when given some [itex]ε>0[/itex] if I set [itex]δ=min(1, ε\sqrt{2})[/itex] and I choose a point [itex](x, y)[/itex] such that [itex]\sqrt{(x-1)^2+ (y-1)^2}<ε\sqrt{2}[/itex], then certainly [itex]|y-1|+|x-1|<ε[/itex] and, by extension,
[tex]\left|\frac{xy}{x+y}- \frac{1}{2}\right|<ε[/tex]
What's wrong with my rationale? :-)
jgens
#4
Jan19-12, 11:43 AM
PF Gold
P: 1,622
Quote Quote by pureza View Post
I did not read anything other than this line so I cannot comment on anything else you wrote, but this is wrong. Take (x,y) such that ε < [(x-1)2+(y-1)2]1/2 ≤ ε21/2. Then notice that [(x-1)2+(y-1)2]1/2 ≤ |x-1|+|y-1| to find (x,y) with [(x-1)2+(y-1)2]1/2 ≤ ε21/2 but ε < |x-1|+|y-1|.
pureza
#5
Jan19-12, 12:13 PM
P: 3
Obviously, you are right (thank you). Take [itex]ε=1[/itex]. I can choose a point in the circle with radius [itex]\sqrt{2}[/itex] that is not inside the square [itex]|x-1|+|y-1|<1[/itex].
How about this: if I choose a point inside the circle with radius ε, then that point is also inside the square with side 2ε, because the circle is contained within the square.
Therefore, if I set [itex]δ\leq ε[/itex], then I know that any point inside the circle with radius δ verifies [itex]|x-1|+|y-1|<ε[/itex], which, if the first part of my derivation is correct, implies that
Is this correct?
Register to reply
Related Discussions
Delta Epsilon Proof of a Limit Calculus & Beyond Homework 9
Delta Epsilon Limit Proof Calculus & Beyond Homework 1
Delta/Epsilon Limit Proof Calculus & Beyond Homework 5
Delta Epsilon Limit Proof - f(x,y) = xy Calculus 4
Epsilon-Delta Limit Proof Calculus 9
