Why is this a linear differential equation?
The discussion revolves around the classification of the differential equation y' - 2xy = x as linear or nonlinear. Participants are exploring the characteristics that define linearity in differential equations, particularly in relation to the terms involved.
  • Some participants attempt to clarify that the equation is linear in y and discuss the implications of having certain terms, such as y^2 or exp(y), for nonlinearity. Others introduce the concept of linear operators and their properties in relation to the equation.
Participants are actively engaging with the definitions and properties of linear differential equations. There is a focus on the linearity of the operator involved and the implications for solutions. Multiple perspectives on the classification are being explored without a clear consensus.
There is mention of the homogeneous case and the conditions under which linear combinations of solutions hold true, indicating a nuanced understanding of linearity in the context of differential equations.
SMA_01
Why is y'-2xy=x a linear differential equation? I thought it would be nonlinear due to the 2xy...?
It is linear *in y*; it would be a nonlinear DE if it contained things like y^2, exp(y), 1/(1+y), etc. Another way to see it is: if y1 and y2 are two solutions and a, b are constants, then the linear combination a*y1 + b*y2 is also a solution. That would generally fail for a nonlinear DE.
RGV
RGV
Sorry: I mean that the above linear combination property is true of the _homogeneous_ equation, with 0 on the right-hand-side; it may, of course, fail for a nonzero right-hand-side. Also: I should have mentioned that a DE is nonlinear as well if it has terms nonlinear in y and/or y', such as y*y' or (y')^2, etc.
RGV
Another way of looking at it is to consider the operator [itex]L=\frac{d}{dx}-2x[/itex], so that the differential equation becomes [itex]Ly=x[/itex]. Then we say the differential equation is linear if that operator [itex]L[/itex] is linear, i.e. [tex]L(f+g)=L(f)+L(g)[/tex] and [tex]L(cf)=cL(f)[/tex] for all (suitably smooth) functions [itex]f[/itex] and [itex]g[/itex] and constants [itex]c[/itex] (where addition of functions and multiplication of a function by a constant are defined point-wise as usual). This is equivalent to what Ray Vickson just said: if you consider the equation [itex]Ly=0[/itex], then (as a result of the linearity of [itex]L[/itex]) any linear combination of solutions is also a solution.
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 27 ·
