Why does tape distribute static charge unevenly?
  • Context: Graduate
  • Thread starter Thread starter Nienstien
    Charge Static
The discussion revolves around the phenomenon of static charge distribution when two pieces of Scotch tape are separated, exploring the underlying mechanisms and factors influencing charge polarity and magnitude. The scope includes conceptual reasoning and experimental observations related to electrostatics.
  • One participant questions how two identical materials can distribute charge unevenly, suggesting that the triboelectric series typically governs charge distribution in non-friction events.
  • Another participant notes that the top tape being stuck to the smooth side of the bottom tape may explain the differing charges, although this is contested by others.
  • A different viewpoint suggests that the experiment works even with the sticky sides facing each other, raising further questions about the mechanism at play.
  • One participant proposes that the Earth's electric field might influence the charge distribution, although they express skepticism about its effectiveness due to its relatively low strength.
  • Another participant speculates that the process of pulling the top tape off the lower tape may leave electrons behind, resulting in a positive charge on the moving tape, and suggests that the speed of removal could affect the charge magnitude.
Participants express differing views on the mechanisms behind the charge distribution, with no consensus reached on a singular explanation. Multiple competing hypotheses remain under consideration.
There are unresolved questions regarding the influence of adhesive properties and environmental factors, as well as the specific conditions under which the experiment is conducted.
Nienstien
There's a popular experiment where you get two pieces of Scotch tape and label one top and one bottom. You attach them together on their sticky sides and then pull them apart and they will attract showing that you can get static electricity without friction. Anyhow, when I thought about it I had a couple problems with how this worked out.
How can two like materials distribute charge unevenly? Isn't charge generally governed by the triboelectric series for non-friction events?
Also, the top tape was consistently positive and the bottom tape was consistently negative (Two top tapes from different trials would repel). This rules out a random event such as how the factory applied the adhesive.
I've researched a bit about the adhesive in tape and found that they are either chemically bonding or experiencing dispersive adhesion which involves Van der Walls attraction.
How can adhesives react like this to consistantly provide opposite charges if they are the exact same thing?
This question has been bothering me for a while and I'd like to get to the bottom of it. Thanks
According to descriptions found elsewhere on the web, in this experiment the TOP tape is stuck to the smooth side of the BOTTOM tape, which explains why they acquire different charges and attract one another.
I've seen that version too but it works with the sticky sides facing as well which is questioning part. If you have tape you can try it for your self.
I wondered if it had anything to do with the Earth's electric field (which is directed downwards). In that case I'd have thought the top tape would become negative and the bottom positive. Anyway, a typical value for the field is 100 volts per metre, which is, I'd have thought, too low to cause enough charge separation for observable attraction. So I think we can rule out this explanation. Pity because it would account for the top/bottom symmetry-breaking.
Do you always pull the top tape off of the fixed lower tape.
My guess is that the moving tape will leave electrons behind and be positive.
Also, the speed of removal may affect the magnitude of the charge.
25K
  • · Replies 21 ·
