RC circuit switching at t=0 from A to B
The discussion revolves around an RC circuit where a switch transitions from position A to B at time t=0. Participants are exploring the implications of this switch on the voltage waveform at point B, particularly focusing on charge redistribution between capacitors and the behavior of the circuit during this transition.
  • Participants are questioning the absence of a resistor in the circuit and discussing the implications of this on the circuit's behavior. There are differing views on the instantaneous changes in voltage and current, with some suggesting that sparks may occur due to inrush currents, while others argue against the occurrence of sparks in circuit theory. The conservation of charge and energy in the circuit is also a point of contention, with one participant raising a question about the apparent loss of energy after the switch is made.
The discussion is active, with various interpretations being explored regarding the behavior of the circuit upon switching. Some participants are providing guidance on how to approach the problem by introducing a resistor to analyze the circuit's response, while others are contemplating the implications of energy conservation in the context of the circuit's operation.
There is a noted confusion regarding the naming of the circuit as an RC circuit despite the absence of a resistor. Participants are also grappling with the theoretical implications of instantaneous changes in voltage and current, as well as the physical phenomena that may occur during the switching process.
paddu123
For the attached rc circuit, at time 0, the switch switches from A to B, how to figure out the voltage wave form at B?
When switch switches from A to B, charge has to redistribute between capacitors, but as the voltage across capacitor C2 can't change instantaneously initially there is a spark and charge distributes slowly. Please help me if this is right to interpret or not?
I do not see any R. Where is it? ehild
Hi ehild,
Yes. No R in the circuit. Just named it as rc circuit. Sorry for the naming convention confusion.
Thanks,
paddu
There are no sparks in circuit theory.
There will be an infinitely short time of infinite current and voltage will instantaneously change.
You've opened up a can of worms! You're going to hear all kinds of loopy explanations probably, including my favorite which is that electromagnetic radiation takes place.
First, if you saw a spark it must have been due to the large inrush current from C1 to C2. As the connection is made, impedance Z changes in finite time from ∞ to 0. So i2Z can be pretty large for a very short time, even causing visible heating, e.g. sparks.
But the real issue is not that: let's say both C1 and C2 are equal in value: C1 = C2 = C. So that initially C1 is charged up to Q1 = C*V, while Q2 = 0. Then, so that charge is conserved, Q1' + Q2' = Q1. OK, so Q1' = Q2' = Q1/2 and V' = V/2. All OK so far.
But then some weisenheimer notices that the energy stored in C1 and C2 is less after the switch than before: energy before = (1/2)CV2, energy after =
(1/2)C(V/2)2 + (1/2)C(V/2)2 = (1/4)CV2! Oops, where did the other half of the energy go?
I'll leave it there for you to contemplate asnd read all the pings you get. I'll rejoin the fray later one way or another.
Rude man has brought up lots of fun questions. Before the thread itself gets short circuited, insert a resistor R in series with the switch and solve the equations using R. Then allow R->0. This will take you to the correct answer in the same way as finding the limit of x/x as x->0.
If you want to blow the instructor's mind, answer Rude man's riddle about where the energy went using the equations you derive. I promise you'll get a good grade in the class.
  • · Replies 19 ·
