| New Reply |
.xyz - mol file inputter method for moleculer viewer in java+JOGL |
Share Thread |
| Jan22-12, 05:29 PM | #1 |
So basically i am developing a molecular viewer in java with opengl bindings (JOGL) and i am having problems with creating an importFile() method. This method will be responsible for importing all the data from .xyz (mol) files. It is a crucial point because the whole 3D Opengl part will rely on the data imported by this method.
153 Si -8.2202000000 -5.6491900000 -1.5237200000 Si -7.3205700000 -7.6948600000 -0.7860500000 Si -6.3849500000 -3.8557600000 -4.4003200000 Si -6.3816400000 -5.7792300000 -3.0557700000 Si -4.4540900000 -1.9259100000 -7.0791000000 Here is an example from an .xyz file which contains the number of atoms at the top, then there comes the symbol of each atoms and the x, y, z, coordinates for each atoms of the molecules. OpenGl will create a sphere for each atom in the xyz files and the bonds by the Van der Waals radius values . I want to import them for easy usage with OpenGL and to create a basic default table model in java to show the imported data separately. I tried to do this method already but without any success. Somehow all the coordinates and symbols should be stored in an array which can be accessed by OpenGL and the table. I would really appreciate that if someone could help me with a bit of code or advice how i should implement it. I dont want to stick to this way of import because i think it is not the best one but looked quite easy at first (i mean with tokenizer) so please share your ideas and codes about this Code:
public void importFile() throws IOException
//the selected file
File fileSelected;
//filenamextensionfilter
FileNameExtensionFilter fileFilter;
//create filechooser
JFileChooser fileChooser = new JFileChooser();
//arraylist of fileNames
ArrayList<String> fileNames = new ArrayList<String>();
//the bufferedreader for importfile method
BufferedReader inputFile;
fileFilter = new FileNameExtensionFilter("XYZ", "xyz");
fileChooser.setFileFilter(fileFilter);
int returnVal = fileChooser.showOpenDialog(fileChooser);
double numberOfAtoms;
String [] symbols = null;
Float [] inputX = null;
Float [] inputY = null;
Float [] inputZ = null;
if(returnVal == JFileChooser.APPROVE_OPTION)
fileSelected = fileChooser.getSelectedFile();
String[] fileName = fileSelected.getName().split("\\.");
if(fileNames.contains(fileName))
int i = fileNames.indexOf(fileName);
fileNames.remove(i);
inputFile = new BufferedReader(new FileReader(fileSelected));
int counter = 0;
StreamTokenizer tokenizer = new StreamTokenizer(inputFile);
//INPUTTING
if (tokenizer.nextToken() != StreamTokenizer.TT_NUMBER) {
throw new IOException("Could not understand format : "
+ tokenizer);
} else {
numberOfAtoms = tokenizer.nval;
} // end if
// skip next line
inputFile.readLine();
try {
for(int i=0; i< numberOfAtoms; i++) {
// a set of four tokens constitute the atom
// d) the symbol
if (tokenizer.nextToken() != StreamTokenizer.TT_WORD) {
+ tokenizer);
} else {
int j = 0;
symbols[j] = tokenizer.sval.toLowerCase();
j++;
} // end if
// a) the x coordinate
+ tokenizer);
} else {
int j = 0;
inputX[j] = (float) tokenizer.nval;
j++;
} // end if
// b) the y coordinate
+ tokenizer);
} else {
int j = 0;
inputY[j] = (float) tokenizer.nval;
j++;
} // end if
// c) the z coordinate
+ tokenizer);
} else {
int j = 0;
inputZ[j] = (float) tokenizer.nval;
j++;
} // end if
// and now we can safely add this atom to our list
//molecule.addAtom(symbol, x, y, z, i);
// skip to next line
} // end for
} catch (Exception e) {
throw new IOException("Error reading file : " + tokenizer
+ "\n Exception is : " + e.toString());
} // end of try .. catch block
//TEST
System.out.println(numberOfAtoms+ " " + inputX[0] + " " + inputY[0] + " " +inputZ[0] + " "+ symbols[0]);
// return the "raw" molecule
return;
| New Reply |
| Tags |
| 3d graphics, java, jogl, mol files, molecular viewer |
Similar discussions for: .xyz - mol file inputter method for moleculer viewer in java+JOGL
| opengl and java - jogl installation | Programming & Comp Sci | 1 | ||
| .txt file in java program | Engineering, Comp Sci, & Technology Homework | 6 | ||
| Java Program Input from file, output to file(s) | Engineering, Comp Sci, & Technology Homework | 31 | ||
| Java GUI output to text file | Engineering, Comp Sci, & Technology Homework | 27 | ||
| File not found in Java | Programming & Comp Sci | 0 | ||
