Size of fictional planet based on gravity and density
The discussion revolves around the calculations needed to determine the size and characteristics of a fictional planet with a specific gravitational force and density, as well as its implications for habitability and ecological conditions. Participants explore theoretical aspects of planetary physics, including gravity, density, and the habitable zone related to different star types.
  • Homework-related
  • One participant seeks to calculate the radius and surface area of a planet with a gravitational force of 1.916G and the same density as Earth, noting previous calculations led to an unexpectedly large size.
  • Another participant provides equations from Newton's law of gravitation and Newton's second law to help derive the radius and mass of the planet based on its density and gravitational acceleration.
  • Some participants express uncertainty about their understanding of the provided equations and concepts, indicating a need for clarification.
  • There is mention of the habitable zone and its relevance to the fictional planet's star system, with one participant expressing frustration over the lack of useful calculators for determining habitable zones for various star types.
  • One participant discusses the ecological conditions of their fictional planet, including extreme weather phenomena, and shares challenges in researching relevant meteorological data.
Participants generally agree on the need for calculations related to the planet's size and habitability, but there is no consensus on the specifics of the calculations or the implications of the habitable zone related to different star types. The discussion remains unresolved regarding the best approach to these calculations and the ecological aspects of the fictional planet.
Participants acknowledge limitations in their understanding of the equations and concepts discussed, as well as challenges in obtaining accurate data related to star classes and meteorological phenomena for their fictional settings.
rdanner3
Given a planet of the same (relative) density as Earth, and a G-force on said planet of 1.916G, what is the procedure to determine the radius and surface area for such a planet, given it having only 57% water coverage?
I will admit that I am working on this for a book series I started in 2002, but my initial calculations obtained a ridiculously large planet size (17x Earth's surface area). Clearly, my own efforts were (at the time) incorrect equations, but I will admit that my math skills may not be up to the task, although much of the data I originally based the calculations on have been lost. Other planets in my series are Earth-type, albeit different due to the stars they orbit being far different from our Sun.
I want to ultimately be able to explain why such a planet would have a rotational period of 100,000 seconds, and an orbital period of 1,000 of those rotations (roughly 3.17 Terran years), yet be habitable.
Bear in mind that I am not requesting that someone do the work, just help me obtain the knowledge needed to do the work myself for this project.
Astronomy news on Phys.org
Awesome project. Have you considered issues concerning the Habitable Zone?
The surface area of a planet is given by the radius (to good accuracy at least). Thus you just need the radius which is included in the equation for Newton's[/PLAIN] Law of Gravity:
[tex]F_g = G_N\frac{M_p m}{R^2}[/tex]
Where [itex]G_N[/itex] is Newton's constant; [itex]M_p[/itex] is the mass of the planet, and [itex]m[/itex] is the mass of the secondary object (e.g. a person feeling the force), and finally [itex]R[/itex] is the radius of the planet.
From Newton's second law:
[tex]F = F_g = m a[/tex]
where 'a' is the gravitational acceleration (on Earth this is usually called 'g'; what you called 'G').
You can combine these equations to remove 'm'. Also, you want [itex]a = 1.916 g[/itex].
The only other thing you need to solve for is the total mass of the planet, which is determined by its density and size:
[tex]M_p = \frac{4\pi}{3} \rho R^3[/tex]
where [itex]\rho[/itex] is the density (which you can look up on wikipedia for the earth---the amount of surface water won't make any noticeable difference).
Yes, I have, but finding correct data on the different star classes (or an actually-working visual calculator!) has been interesting.
zhermes said:
The surface area of a planet is given by the radius (to good accuracy at least). Thus you just need the radius which is included in the equation for Newton's Law of Gravity:
Okay, that does make sense, insofar as I actually understand what you've mentioned. I would be incorrect if I said I understood all of this. :-) And I acknowledge your near-rebuke regarding g and my incorrect use of the uppercase G for it. LOL
The only Habitable Zone "calculator" I've seen at all is useless for what I need; it only shows three very-general star types (basically, small, medium, super-huge) and is leaving me totally unable to figure out other critical data in re: the star classes of these star systems. Based on what I know (the orbital year of two of the planets), I expect one of the stars is a close cousin (so to speak) of the star we ourselves orbit. The one for Regelis, on the other hand, appears to be much hotter, as the HZ is obviously much further out from the star.
Based on the apparent ecology and temperature spreads I have created for Regelis (and the fact that their hurricane classification system has 10(!) steps, not 5, as ours does) I expect that Regelis is closer to the inner edge of its system's HZ than Earth is.
Worst directly-referenced hurricane (in the novels) has been a Class 7, although class 10s have been indirectly referred to, largely in historical context. (Either one would be intensely dangerous, probably destructive beyond anything we have concept of, to be honest.) Closest I can figure for the Class 7 is somewhere around 2000km across, with wind speeds exceeding 250mph, although meterology is decidedly not my strong suit. Been trying to research certain data from well-known storms now for several hours, to little effect. :-\
  • · Replies 24 ·
