Find Velocity of Frame for Simultaneous Occurrence of Events A & B
The discussion revolves around finding the velocity of a reference frame in which two events, A and B, occur simultaneously. The events are described as being separated by a lightlike interval, and the original poster seeks to determine the conditions under which they can occur at the same time and location in a different frame of reference.
  • The original poster attempts to equate the time coordinates of the events in different frames but encounters a contradiction. Some participants question the implications of the lightlike interval and whether a frame moving at the speed of light is feasible. Others explore the nature of spacelike intervals and their relationship to simultaneity.
Participants are actively engaging with the problem, offering insights into the physical implications of lightlike and spacelike intervals. There is a recognition of the complexity of the situation, with various interpretations being explored. Some guidance has been provided regarding the invariance of the spacetime interval.
Participants note the constraints of the problem, including the definitions of lightlike and spacelike intervals, and the implications for simultaneity in different reference frames. There is an acknowledgment of the challenges posed by the original poster's approach and the need for careful consideration of the physical context.
khfrekek92
events A(ct,x)=(1m, 2m) and B(ct,x)=(3m,4m) are separated in a lightlike interval. I need to find the velocity of a separate reference frame in which they BOTH occur at the same time.
Next I need to find the velocity of the frame where they will occur at the same LOCATION.
t=(gamme)t'
To solve for this, I need to find where the t' for both events is equal. But when i set tb'=ta', everything cancels out and I end up getting 1=3. Is there any other way of doing this that I am missing? I am getting the same problem with the location part as well.
Thanks in advance!
Or am I just doing this completely wrong?
This problem appears to have been designed to force you to think about the physical situation it describes before you jump into the equations and formulas. Think about why we use the word "lightlike" to describe some intervals.
Hmmm... Well Lightlike means they are only in a causal relationship if you use light. So would the frame of reference have to moving at speed c? I thought you can't have a frame moving at speed c?
That's a bingo!
Oh! Duh, why didn't I think of that? So if they were in a spacelike interval, you still wouldn't be able to have them happen at the same time, would you?
A better description of lightlike separation might be that a flash of light could have been emitted at one event and absorbed at the other... But this definition will bring you to the same result.
Remember that ds^2 is an invariant. This means that if ds^2=0 in one frame, then it is 0 in all frames. Further, this means that ds^2 can never change signs. 2 events which occur at the same time must have ds^2<0 (assuming metric (+ - - -)), and 2 events which occur at the same point in space must have ds^2>0.
Either you have it backwards or you're typing too quickly: spacelike separation means that they'll be always be at different locations, but you can find a reference frame in which they happen at the same time or either one before the other.
I just did a similar problem, but with runners in a time-like interval. The problem was that two runners were racing, one runner was given a time handicap, find an inertial frame where the handicap doesn't exist. You don't have to going at the speed of light for something to APPEAR to happen at the same time from another frame. The question was pretty open-ended (Jackson...), but I basically said/found that if these are regular human runners you'll have to be going much faster for relativistic effects so just ignore velocity addition (or travel perpendicular to running motion), and there was a definite speed at which an observer in K' claims the runners started at the same time. Just wanted to throw this bit of info at you to add to confusion :p
Haha! Thanks so much guys, I finally got all of them done (there was one problem for finding equal times AND distances for each of the three intervals.) Thanks so much for all of your help!
-Zack
