Kochen-Specker As Simple Corollary Of Gleasons Theroem
  • Context: Graduate
  • Thread starter Thread starter bhobba
The discussion revolves around the relationship between Gleason's theorem and the Kochen-Specker theorem, particularly whether the former can be viewed as a simple corollary of the latter. Participants explore the complexities of the proofs of these theorems, their presentation in textbooks, and the implications of newer, simpler proofs based on Positive Operator-Valued Measures (POVMs).
  • Some participants suggest that the proof of Gleason's theorem is difficult, which may explain its absence in many quantum mechanics textbooks.
  • One participant mentions that a simpler proof of Gleason's theorem based on POVMs has been found, raising questions about why this approach is not more widely presented.
  • Another participant notes that understanding the statement of Gleason's theorem requires knowledge of terms like "probability measure" and "lattice," which may not be familiar to physics students.
  • Concerns are raised about whether the new proof based on POVMs truly encompasses Gleason's theorem or if it represents a different theorem altogether.
  • A participant explains the concepts of probability measures and frame functions in the context of Gleason's theorem, emphasizing the challenges in proving linearity.
  • Discussion includes references to Neumark's theorem, which is suggested as a means to simplify the proof using POVMs.
Participants generally agree that the complexity of the original proof of Gleason's theorem is a barrier to its inclusion in textbooks, but there is no consensus on whether the newer proofs adequately capture the essence of Gleason's theorem or if they represent a distinct theorem.
Limitations include the assumption that participants have varying levels of familiarity with advanced concepts in quantum mechanics, such as POVMs and probability measures, which may affect their understanding of the discussion.
I have been mucking around with Gleasons therom of late and noticed it was mentioned in some literature it has the Kochen-Specker theorem as a corollary and thought what the heck let's see if I can prove it. It was trivial which started me thinking why it is not presented that way in textbooks. All I can think is that maybe it is thought the proof of Gleasons is a bit hard. However in recent times a quite simple proof based on POVM's has been found. So maybe I am missing something. Anyone got any other ideas or is it simply the newer proof of Gleasons theorem haven't filtered down to the textbooks yet?
Thanks
Bill
The proof of Gleason's theorem doesn't appear in any QM textbooks I know of, except "Geometry of quantum theory" by V.S. Varadarajan, which is one of the hardest books I've ever seen. Most people probably wouldn't even consider it a QM book, because of all the projective geometry stuff in it.
Yea the proof of Gleasons Theorem as originally done by Gleason is a ripper - I have been though it - groan. But a new much simpler version has been found - see the second chapter of:
http://kof.physto.se/theses/helena-master.pdf
My suspicion from what you wrote is its the toughness of the older proof that is the reason its not done that way.
Thanks
Bill
Yes, I think your suspicion is right. But it's not just that the proof is hard. If that had been the only problem, the books could at least have stated the theorem without proof, and then proceeded to derive Kochen-Specker as a corollary. But to understand the statement of the theorem, you need to understand terms like "probability measure" and "lattice", and understand why the set of closed subspaces forms a lattice. Physics students don't know these things.
That thesis looks interesting. I might read it later. I have only studied the statement of the theorem, not its proof. I was a bit inspired by your post last night and decided to take a quick look at the POVM-based proof. http://arxiv.org/abs/quant-ph/9909073. (Another member at the forum mentioned it to me a few weeks ago). It's really short, but I didn't try to understand it right away, because I didn't understand what he meant by "effects". I got the impression that the book he coauthored, "Operational quantum physics", would be a good place to read about those things, so I may have to read a chapter or so of that book first. (I know almost nothing about POVMs. I recently started a thread where I asked for suggestions about what I should read to understand them, and got a lot of suggestions, but I haven't studied any of them yet).
Have you studied this proof? Since I have only had a quick look at it, I obviously don't understand it, but one thing bothers me about it. Gleason's theorem finds all the probability measures on the lattice of closed subspaces. The first thing Busch does is to make the domain larger, so apparently we're now trying to find all probability measures on a larger lattice (it's still a lattice, right?), the lattice of all "effects". So do we really end up with Gleason's theorem, or is this just a similar theorem?
I have studied both proofs and interestingly you don't really need to know concepts like probability measure, lattice etc - they are not that hard really - but you don't need to know it.
If you imagine a finite dimensional (for simplicity) complex vector space partitioned into a number of sub-spaces by a set of projection operators Ei (ie as resolution of the identity or PVM - Projection Value Measure) then you know for sure that the outcome of some observation must be a vector that lies in one of those sub-spaces so you can associate a probability with each of the projection operators. A probability measure is simply an assignment of probabilities ie a number between zero and one such that if what you define it over is disjoint then the probabilities are additive. Since the Ei are disjoint the probability associated with them is additive. This probability measure in Gleason parlance is known as a frame function denoted by f. What Gleasons theorem says is there is only one way to define a probability on such a vector space - the standard trace definition of QM which is a generalization of Born's rule
Now any Hermition operator A can be uniquely expressed as A = sum Yi Ei where each Ei is a disjoint projection operator and allows us to extend f to Hermition operators by defining it as f(A) = sum Yi f(Ei). From Hermtian operators you can extend it to all operators since any operator can be expressed as the sum of a Hermtian operator and an imaginary one (ie a Hermtian operator multiplied by i). This would solve the problem except for one thing - you need to prove f is linear. That is the real hard part and Gleasons proof of it is a real doosey - and justifiably famous. He does it starting with POV's and its a long hard slog.
However what some bright spark noticed is if you start from what is called POVM's (positive Value Measures) instead of PVM's then the proof is a lot easier. A POVM is a generalization of a PVM. A PVM is a resolution of the identity ie disjoint projection operators Ei such that Sigma Ei = 1. We have each of the Ei assigned a probability. A POVM is a set of positive operators Fi such that sigma Fi =1 - however the Fi (called Effects) do not have to be disjoint - and it is easy to show that their eigenvalues are less than or equal to one. From the extension of the frame function you can see they all have frame functions less than one and if additive should add up to one. But how do you know its additive? Here is the trick. Suppose you are in a higher dimensional vector space and you have a PVM then if you project this onto a lower dimensional sub-space it forms a POVM in that sub-space and 'induces' a probability onto the POVM so it adds up to one - ie you know they form a disjoint probability measure in the higher dimensional space - careful here - the projection can't be zero or it won't be as easy to see. Neat trick - but can this be done for all POVM's - yep - a neat theorem called Neumark's theorem says you can always do it. Basically you have now simplified the problem by physical insight. For further details check out:
http://www.theory.caltech.edu/people/preskill/ph229/notes/chap3.pdf
Yes the set of POVM's is larger than the set of PVM's but the trick is by using Neumark's Theorem you can find a higher dimensional space such it is the projection of a PVM and each effect can be assigned the frame function of the corresponding projection in the PVM.
To really get what is going on you need to go through the theorem in Chapter two of the link on Gleasons Theorem or the link you gave.
Thanks
Bill
  • · Replies 54 ·
12K
  • · Replies 37 ·
  • · Replies 82 ·
11K
  • · Replies 23 ·
