Finding the coefficient of kinetic friction
by Skysong12
Tags: friction, newton's law
Skysong12
Skysong12 is offline
#1
Jan28-12, 08:00 PM
P: 2
A construction worker passes a brick to another worker by pushing it across a wooded floor. the brick has a mas of 2.7kg. The force required making the brick move with acceleration of 0.42m/s2 is 28 N. What is the co-efficient of kinetic friction acting on the brick?
3. The attempt at a solution
FN=Fg
= mass X acceleration
=2.7kg X 0.42m/s2
=1.134 N
Fkf= μk X FN
μk = Fkf [itex]/[/itex] FN
= 28N [itex]/[/itex] 1.134N
=24.69
I'm pretty sure I got the acceleration part wrong. What am I supposed to do to find the normal force?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
rock.freak667
rock.freak667 is offline
#2
Jan28-12, 08:21 PM
HW Helper
P: 6,213
0.42 is the resultant acceleration so multiplying that by 2.7 kg will give you the resultant force.
28 N is the applied force, you are correct in that Fkf = μk X FN.
So what equation can you make to relate the 28 and Fkf ?
(Hint: A free body diagram will help you if you can't visualize it in your head)
gneill
gneill is offline
#3
Jan28-12, 08:27 PM
Mentor
P: 11,419
Quote Quote by Skysong12 View Post
FN=Fg
=2.7kg X 0.42m/s2
=1.134 N
Fkf= μk X FN
=24.69
Hi Skysong12, welcome to Physics Forums.
The normal force for a mass M on a horizontal surface has magnitude M*g.
Where you started to calculate FN above you used the horizontal acceleration of the brick rather than g = 9.81 m/s2. So what you got instead of the normal force was the net horizontal force acting on the brick (the net horizontal force that results in the given acceleration of the brick of mass M).
The net horizontal force should also be equal to the difference between the applied force and the force due to friction: [itex] F_{net} = f_{applied} - \mu_k F_N [/itex]
Register to reply
Related Discussions
Finding the Coefficient of Kinetic Friction Introductory Physics Homework 1
Finding coefficient of kinetic friction Introductory Physics Homework 4
need help finding coefficient of kinetic friction Introductory Physics Homework 4
Finding the coefficient of kinetic friction Introductory Physics Homework 2
