| New Reply |
Time Moves Forward for Obvious Reason? |
Share Thread | Thread Tools |
| Feb13-12, 06:05 PM | #69 |
Time Moves Forward for Obvious Reason?If an object is moving in a straight line (as opposed to a curved line) in spacetime, then all observers will agree that the path is a straight line, even though their observations may not be observed at the same times in their own frames. Past events are never altered. "...unraveling the log’s past..." What does a burning log have to do with the past? That is perhaps a little poetic, but as James_Harford says, it has nothing to do with physics. |
| Feb13-12, 08:50 PM | #70 |
Again I disagree, they (physics) have to rely upon an objective now, this is how it is defined...right....now. It of course is not an absolute "now". distance across space has an invariant isotropic speed limit. |
| Feb13-12, 11:11 PM | #71 |
I think you are on the right track. Independent estimates of the size and mass of our universe place it entirely within its own Schwartzschild radius, where the radial dimension and time switch roles due to a sign change in the metric. My theory is therefore that we are in a humongous Black Hole, and that the inexorable chute towards the central singulaity is the inexorable passage of time, while the unbounded outside time dimension becomes unbounded space inside. An interetsing consequence is that "where" quesions and "when" questions have to be interchanged. So the answer to "Where is the event horizon?" is "13.5 billion years ago", and the answer to "What came before the Big Bang" is "The Outside".
Thus I equate the instant of the Big Bang with the event horizon, "seen" from the inside. From that instant, everything evolved more or less as we know it. I have done the math and the interior universe is one that exhibts an initial infinite rate of expansion, falling to 70Km/s/Mpc at the plateau phase, and then accelerating towards the Big Rip, and infinite rate expansion which will occur of the order of 10 billion years hence. Now, such Robertson-Walker-like metrics are normally associated with a uniform density of matter. This matter density has to be an order greater than the visible matter density to explain the observed expansion rate; hence the Dark Matter hypothesis. But I don't need any Dark Matter. I get the expansion due to the mass of the Black Hole, 90% of which is already at the central singulaity, or at least nearer to it than we are - which means it is displaced in time from us to our future, and that is why we can't interact with it. Now, the orbits of stars around galaxies follow geodesics of the spacetime, and they in turn are totally determined by the metric. So, they will conform to the geodesics of a universe filled with Dark Matter even though it's not, as the math can't tell the difference. Thus anomalous galactic rotation explained. |
| Feb13-12, 11:45 PM | #72 |
"The only way that spacetime can evolve on its own is to be part of the physics of a larger 5-dimensional space with a second dimension of time in which it can evolve. That would be bizarre, since it suggests a past that is not static. But since this is not the case, spacetime merely "exists" and does not "evolve". "
I am reminded of Spielberg's SciFi movie "The Langoliers". These were monsters that followed behind us in time to chomp up the spacetime past we left behind us. Now, with reference to my previous post, where I equate the passage of time with the our inexorable chute along the radial dimension of the interior of a humongous Black Hole, we can place numbers along the radial dimension such as Jan 1 1900, Jan 1 1901, Jan 1 1920 .... Jan 1 2012. Now we ask, if an observer using H.G. Wells' time machine could change his time coodinate from today to Jan 1 1900, what would he see? I say he would not see our universe as it was then, because he did not take our universe back with him. He will see the stuff that is following us 112 years behind in time along the radial dimension. That is a different universe that is now occupying the spacetime coordinates that we once occupied - The Langoliers, no less! So we really do need another dimension along which we can plot the evolution of events in our universe. We occupy a certain 4D region of spacetime at one value of this new axis, and something else occupies the same 4D spacetime at a different value along this axis. We shouldn't worry about that. Heck, string theorists are into 7 and 11 dimensions and I have also seen suggestions that the number of dimensions must be a large Fermat prime! |
| Feb14-12, 02:16 AM | #73 |
- Regards. |
| Feb14-12, 09:16 AM | #74 |
Hi James,
I have been thinking about our exchange, but I have also been very busy, sorry for a late replay. After considering our topic, I do have to agree with you, but unfortunately (and if you can believe it), not for the reason/definitions you give. First off in this quote You also seem to be saying that the static nature of our universe is a consequence of no apparent outside time variable, which seems weird to me through and through, as I said last time. So before I say I why I interpret the universe as static, I guess I want you to answer me a question, and perhaps we can talk about this question specifically in another thread; If the universe is static, who is it static with respect to? My understanding of the universe being static comes from the Hamiltonian formulation of GR. In this, GR is a completely constrained system, that is, there is no dynamics term. The whole hamiltonian vanishes. Each constraint lends itself to a geometric meaning, that describes the shape of spacetime. Talk to you later, |
| Feb14-12, 09:51 AM | #75 |
If instead of the terms "objectively" and "subjectively", I think it would be best to use the words "relative" and "invariant". If "subjective = relative" & "objective = invariant" then yes I agree with you. I also feel there is no disputing measurements of time or length with in an FoR, both of which require a "now" (in particular length). In any case this is silly to interprut such |
| Feb14-12, 12:58 PM | #76 |
It is interesting that you do seem to see this as primarily a GR question. - Regards. |
| Feb14-12, 01:06 PM | #77 |
| Feb15-12, 12:53 PM | #78 |
Over all I would say matter in the form of atoms, are the most deterministic duration, or maybe dark matter. |
| Feb15-12, 09:51 PM | #79 |
No, I was out of line Petm1. Please do accept my apology. I am new here and trying to find the proper "stance".
I realize that you have a very poetic way of seeing the universe --a way which the discipline of physics tends to strip away. Yet the magic is always present, albeit unremarked, and that is what to which I suspect you are especially attuned. For sure, the evocative nature of poetic vision is very heady stuff, and the essence of what makes life worth living. - Regards. |
| Feb17-12, 08:48 AM | #80 |
For anyone reading this thread who hasn't already noticed: The question, "is spacetime static" that this thread morphed into has independently arisen in the "is time mapped out" thread at http://www.physicsforums.com/showthread.php?t=578434.
Perhaps future discussion on this question should be under that thread? |
| Feb17-12, 09:21 AM | #81 |
PMichaud,
When your milch dissolves in your cofee, you see something irreversible that shows a preferential direction of time (for all things of these same kind). I can't see, however, how milch dissolving in cofee can in any way be related to the assymetric initial conditions of the Big Bang. This does not mean that specific initial conditions could not, indeed, imply some irreversibility in time. There could be several sources of irreversibility, like also at the particle physics level. However, the most familiar arrow of time, the one related to the second law of thermodynamics can hardly be related to the big bang. You might be interrested in this book: The Physical Basis of The Direction of Time, by H. Dieter Zeh. |
| Feb17-12, 12:37 PM | #82 |
I get the impression from this thread that there is a consensus that objects move through time rather than time moving forward and I can agree with that. I think the point that the OP was getting at is that generally things only move in one direction through the time dimension and this makes time special as objects can generally move in either direction, backwards or forwards, through the spatial dimensions. Now the question is, how do we determine this allowed direction for travel through time and is there any sort of "law" that prohibits travel in the negative time direction? Others have already mentioned the thermodynamic arrow of time. This is a statistical probability that systems evolve from a state of low entropy to a state of high entropy and very rarely in the opposite direction. Bahamagreen gave this example:
| New Reply |
| Tags |
| big bang, direction of time, time |
| Thread Tools | |
Similar Threads for: Time Moves Forward for Obvious Reason?
| Exothermic reaction moves forward with increase in Temp? | Biology, Chemistry & Other Homework | 1 | ||
| What 'drives' time forward? | General Physics | 14 | ||
| Backward and forward in time? | High Energy, Nuclear, Particle Physics | 10 | ||
| Why does time seem to exist only in a forward direction? | Cosmology | 16 | ||
| Backward or forward in time? | Special & General Relativity | 8 | ||
