Register to reply
To find out the frequency of AC mains using a sonometer
by Samar99
Tags: frequency, mains, sonometer
Share this thread:
Samar99
#1
Jan29-12, 10:49 PM
P: 1
There is this experiment regarding the frequency of AC mains using a sonometer and I found a slight confusion with the formula. there is an electromagnet attached to a step down transformer and a wire is placed below the electromagnet, and by varying the length and tension, one has to get the maximum amplitude deflection,so as to match the natural frequency of the wire with the electromagnet.
2. Relevant equations
the frequency of oscillation of a wire is given by
f=1/2L√T/μ
where, L= length of wire
T=Tension in the string
μ=Mass per unit length
3. The attempt at a solution
the formula gives the frequency of the wire, not the AC mains. Here in India, AC mains frequency is 50 Hz, so the electromagnet gets magnetized and demagnetized twice in a cycle so the wire should be pulled towards the electromagnet 100 times. So should I halve the frequency that I get from the above formula to get the frequency of AC mains?
Phys.Org News Partner Science news on Phys.org
New model helps explain how provisions promote or reduce wildlife disease
Stress can make hard-working mongooses less likely to help in the future
Grammatical habits in written English reveal linguistic features of non-native speakers' languages
technician
#2
Jan30-12, 01:06 AM
P: 1,506
Everything is OK
When the current flows in one direction the wire experiences an upward force and when the current reverses the force reverses. So the frequency of the wire is the frequency of the AC.
When the amplitude is maximum the wire is resonating at the mains frequency.
The first occasion resonance occurs is when the wire is half a wavelength long.
This is the reason for the 1/2L in the equation
Register to reply
Related Discussions
Mains voltage frequency amplifier? Electrical Engineering 7
Sonometer Experiment Classical Physics 1
Parallel RLC circuit: find resonant frequency and Input at that frequency Introductory Physics Homework 7
Sonometer discussion Introductory Physics Homework 0
