Packing Earth with 1m Extra String - Unexpected Result?
  • Context: Undergrad
  • Thread starter Thread starter wimms
    Earth
The discussion centers on the mathematical implications of adding 1 meter to the circumference of Earth, which is approximately 40,000 km. This addition results in the string lifting off the ground by 16 cm, calculated using the formula for the radius change of a circle (L/2π). The conversation also highlights that this principle applies universally, such that if the orbit of Earth around the Sun or the Sun's orbit around the galaxy were extended by 1 meter, the respective distances would also increase by 16 cm. This unexpected result showcases the non-intuitive nature of geometric relationships.
  • Understanding of basic geometry, specifically the properties of circles.
  • Familiarity with the formula for circumference (C = 2πr).
  • Knowledge of radius and its relationship to circumference changes.
  • Basic algebra skills for manipulating equations.
  • Explore the mathematical derivation of circumference and radius changes in circles.
  • Investigate the implications of geometric principles in astrophysics, particularly orbits.
  • Learn about the concept of infinitesimal changes in calculus.
  • Study real-world applications of geometric principles in engineering and physics.
This discussion is beneficial for mathematicians, physics enthusiasts, educators teaching geometry, and anyone interested in the surprising implications of geometric principles in real-world scenarios.
wimms
This is simple exercise with unintuitive result, perhaps old as hell, but still surprising.
Suppose we wrap Earth with a string along equator, tightly, so that string is touching ground along its whole path. Assume Earth is perfect sphere. Length of this string would be calculated as circumference of earth.
Now imagine we add 1 meter to the total length of this string.
Question is: by how much would this string lift off ground if distance to the ground is kept uniform along whole length of it?
The circumference of Earth is about 40,000km. A change of 1m is 1/400,000%. The radius is 6366.2km. A change of 1/400,000% is 16cm.
This could likely also be figured algebraically (spelled horribly wrong) since you can get the same result by plugging 1m into the radius of a circle equation.
Of course Russ, but you could let people less advanced discover this. :smile:
More general answer is that radius changes by L/2Pi where L is addition to circumference. So, if orbit of Earth around Sun were extended by 1meter, then Earth's distance to Sun would increase by 16cm. If Sun's orbit around galaxy was extended by 1 meter, then its distance to center of it would increase by 16cm..
I wonder if this was intuitively obvious to you?
  • · Replies 75 ·
  • · Replies 0 ·
  • · Replies 66 ·
  • · Replies 23 ·
  • · Replies 94 ·
15K
