Build an Aircraft: What License Do I Need?
  • Thread starter Thread starter cronxeh
    Advise
To build an aircraft powered by a homemade LPG-powered jet engine, you must adhere to FAA regulations. You can construct the aircraft under the "experimental" category, which allows you to bypass the extensive certification process required for production aircraft. However, an inspection is still necessary, which is simpler than the production aircraft certification. For further guidance, contacting the Experimental Aircraft Association (EAA) is recommended.
  • Understanding of FAA regulations regarding aircraft certification
  • Knowledge of the experimental aircraft category
  • Familiarity with aircraft safety standards
  • Basic principles of aircraft design and construction
  • Research FAA regulations on experimental aircraft certification
  • Learn about the inspection process for experimental aircraft
  • Explore resources provided by the Experimental Aircraft Association (EAA)
  • Investigate the design and engineering of LPG-powered jet engines
Aerospace engineers, aviation enthusiasts, hobbyist aircraft builders, and anyone interested in constructing experimental aircraft.
cronxeh
Suppose I wanted to build an aircraft that would be powered by home made LPG-powered jet engine. It would have to carry at least 180 lbs for a pilot plus fuel and all that stuff. If I wanted to fly this thing - what license would I need (FAA or any other 3-letter place)?
FAA must certify that the craft meets their safety standards.
See - http://www.faa.gov/certification/aircraft/air_index.htm
You could build it under the "experimental" category and bypass the certification process required for production aircraft. It still required inspection, but it is a simple process compared to a production aircraft.
Contact the Experimental Aircraft Association for more info. www.eaa.org
-Glenn
9K
  • · Replies 16 ·
  • · Replies 59 ·
10K
15K
