Mathematica Help - Plotting equation with i
  • Context: Mathematica
  • Thread starter Thread starter tarheelborn
    Mathematica Plotting
The discussion centers on using Mathematica to plot the equation r[t_] = 3 Cos[t] + i Sin[t] using the PolarPlot function. Users encountered issues when attempting to include the imaginary unit 'i', as PolarPlot only supports real radii. A suggested solution involves using the Abs function to convert the complex radius into a real value, allowing for successful plotting. The final resolution was achieved using ParametricPlot, which effectively visualized the desired curve after some adjustments.
  • Familiarity with Mathematica syntax and functions
  • Understanding of complex numbers and their representation
  • Knowledge of PolarPlot and its limitations in Mathematica
  • Experience with ParametricPlot for visualizing mathematical functions
  • Explore the documentation for PolarPlot in Mathematica
  • Learn about the Abs function in Mathematica for handling complex numbers
  • Investigate advanced plotting techniques in Mathematica, including ParametricPlot
  • Research complex number visualization methods in Mathematica
Mathematica users, mathematicians, and educators looking to visualize complex functions and enhance their understanding of plotting techniques in mathematical software.
tarheelborn
I cannot seem to make mathematica plot the following equation correctly:
r[t_] = 3 Cos[t] + iSin[t];
plotbeta = PolarPlot[r[t], {t, -Pi/2, Pi/2}]
I have used the capital I to no avail; I have used * to indicate multiplication. It plots the curve without a problem when I leave out the i, but I need the i! I will appreciate your help. Thank you.
PolarPlot[], documented here,
http://reference.wolfram.com/mathematica/ref/PolarPlot.html
plots a Real radius as a function of the angle.
Do you really want to plot a surface in Complex space as a function of Complex radius?
If you want a PolarPlot that plots Complex radii then I don't know what to suggest.
There have been a few example complex plotting functions demonstrated over the years,
I think Roman Maeder developed one of these in the really really old book "Programming in Mathematica."
Or do you perhaps want
r[t_] = Abs[3 Cos[t] + I Sin[t]];
where Abs[] returns the Real distance from the origin to the point 3 Cos[t] + I Sin[t] in the complex plane?
I finally managed to get this using ParametricPlot. It worked beautifully; just took some tweaking! Thank you.
