Vapor Pressure: What Affects Gasoline Evaporation?
The discussion centers on the vapor pressure of gasoline, which ranges from 20 kPa to 80 kPa at room temperature. It is established that gasoline can form vapor clouds in the atmosphere due to the presence of molecules with sufficient energy to escape as vapor, even at temperatures below its boiling point. The vapor pressure is influenced by the temperature and the volatile constituents of gasoline, which is not a pure substance. Additionally, Dalton's Law of partial pressures is referenced to explain how the total pressure of a gas mixture is the sum of the partial pressures of its components.
  • Understanding of vapor pressure concepts
  • Knowledge of Dalton's Law of partial pressures
  • Familiarity with the properties of gasoline as a non-pure substance
  • Basic thermodynamics related to phase changes
  • Research the impact of temperature on vapor pressure in liquids
  • Study the composition of gasoline and its volatile constituents
  • Explore the applications of Dalton's Law in real-world gas mixtures
  • Learn about the environmental effects of gasoline vapor emissions
Environmental scientists, chemical engineers, and anyone involved in fuel technology or atmospheric studies will benefit from this discussion on gasoline vapor pressure and its implications.
Ask1122
Hi all,
I have a question on vapor pressure. As far as I understood, a liquid will flashes into gas when the absolute pressure it is experiencing (in a pipe / in the atmosphere) is lower than the liquid's vapor pressure (assuming temperature is constant).
Everyone knows that gasoline forms a vapor cloud when it is released into the atmosphere. But a lots of sources I came across on the internet states that the vapor pressure of gasoline ranges between 20kPa - 80 kPa at room temperature on average, so if that is true, how does gasoline form a vapor in the atmosphere?
Thank you~
The way I have understood it, is that temperature is just an average. Some of the molecules will have enough energy by chance to escape as vapor at any temperature. The numbers you state are average, and if the average is high enough for vaporization, you get a large scale effect, ie boiling.
Ask1122 said:
Hi all,
Thank you~
Well then, how does water from a vapour in air at room temperature?
The vapor pressure of water at 20 deg C or room temperature is 17.5 mm Hg, yet liquid water still evaporates at atmospheric pressure.
But boiling water at 100 deg C has a vapour vapor pressure is 760.0 mm Hg - ie atmospheric pressure.
The vapour pressure is a function of temperature. If you put a substance in a closed container, an equilibrium will be reached after some time where the pressure of the gas of the substance in the container reaches a value depending upon the temperature. That is the vapour pressure at that temperature. Since gasoline is not a pure substance its vapour pressure varies depending upon its volatile constituents.
Here is an excerpt fom Wiki regarding dalton's Law
Dalton's law of partial pressuresMain article: Dalton's law
The partial pressure of an ideal gas in a mixture is equal to the pressure it would exert if it occupied the same volume alone at the same temperature. This is because ideal gas molecules are so far apart that they don't interfere with each other at all. Actual real-world gases come very close to this ideal.
A consequence of this is that the total pressure of a mixture of ideal gases is equal to the sum of the partial pressures of the individual gases in the mixture as stated by Dalton's law.[2] For example, given an ideal gas mixture of nitrogen (N2), hydrogen (H2) and ammonia (NH3):
where:
= total pressure of the gas mixture
= partial pressure of nitrogen (N2)
= partial pressure of hydrogen (H2)
= partial pressure of ammonia (NH3)
It takes some time to get your head around all of this vapour pressure stuff I know.
  • · Replies 39 ·
  • · Replies 27 ·
  • · Replies 0 ·
