| New Reply |
Unruh Effect |
Share Thread |
| Jun5-12, 10:35 PM | #35 |
Unruh Effect* From the viewpoint of an observer who is accelerated with the detector, the detector absorbs a particle and registers a corresponding increase in energy, and changes its motion slightly as a result of the absorbed particle's momentum. * From the viewpoint of an inertial observer, the detector *emits* a particle, and registers a corresponding *decrease* in energy and a change in momentum due to "radiation reaction". The underlying quantum field viewpoint is that there is a state transition from the "inertial" vacuum state to the "accelerated" vacuum state (which the inertial observer does *not* see as a vacuum state), and a corresponding state transition in the detector, as required by the appropriate conservation laws. It all hangs together, but I admit it is certainly not intuitive. |
| Jun6-12, 12:28 AM | #36 |
Next question. As I understand it, the Unruh particles are only observed coming from behind the accelerating observer from the location of the Rindler horizon. Any intervening cold wall between the Rindler horizon and the accelerating observer casts a shadow that seems to block the Unruh radiation. Now let's say that we have one accelerating object that has an intervening wall between it and its Rindler horizon and another accelerating object that does not have an intervening wall between it and its Rindler horizon. Would the inertial observer now see a radiation reaction and particles being emitted from the accelerating observer without an intervening wall and no radiation reaction or particles emitted from the accelerating object with no intervening wall behind it? Is not radiation reaction an intrinsic part of accelerating particles and shouldn't it be independent of any wall behind the accelerating object? |
| Jun6-12, 05:10 AM | #37 |
Anyway, according to this (as I said, old-fashioned) way of looking at things, a positron is not a negative energy electron, it is the absence of a negative energy electron. By the way, this way of viewing a hole in an otherwise filled shell of electron states as a positively-charged particle is no longer used in quantum field theory, but is still commonly used in solid-state physics, especially semiconductors. |
| Jun6-12, 06:31 AM | #38 |
In fact, the Rindler vacuum is a superposition of various Minkowski-particle states all of which have a POSITIVE energy. Technically, this superposition of positive energy states is known as a squeezed state. Minkowski particles and Rindler particles are states in the same Hilbert space. Two definitions of particles correspond to two definitions of particle-number operator which do not commute. The fact that the same state |0> may be either vacuum or not-vacuum with two different definitions of the particle-number operator is analogous to the more familiar fact that the same spin-1/2 state |down> may be either down or not-down state with two different definitions of the z-axis. More physically, just like rotation of the Stern-Gerlach apparatus (which measures spin) may turn down-state into a not-down state, acceleration of a particle detector may turn vacuum state into a not-vacuum state. |
| Jun6-12, 09:15 AM | #39 |
| Jun6-12, 10:49 AM | #40 |
| Jun6-12, 10:56 AM | #41 |
* For acceleration in a circular path, there is no Rindler horizon (I think that's right) and no Unruh effect (I think that's also right but I'm not sure). * For the "acceleration" of objects at rest on the Earth's surface, the Rindler horizon is not "visible" because the spacetime is curved--the Earth is only 4000 miles in radius but the Rindler horizon would be a light-year away for a 1 g acceleration. So there is no Unruh effect here either (again, I think that's right for the Earth--but note that for a black hole, there is Hawking radiation, the mathematics of which is very similar to that of the Unruh effect). |
| Jun6-12, 07:37 PM | #42 |
It seems physically reasonable to me that uniform circular motion will be accompanied by something like the Unruh effect, although the details are more complicated.
For example, Bell and Leinaas have a series of papers, 25+ years old now, where they try to interpret the known partial spin polarization of electrons orbiting in a storage ring as experimental evidence in favor the unruh effect. The original paper is I think http://www.sciencedirect.com/science...50321387900472 while an accesible discussion is at http://arxiv.org/pdf/hep-th/0101054.pdf Another discussion of radiation in the circulating case can be found at http://arxiv.org/abs/gr-qc/9903054 I'm not sure about this "cold wall" situation, mostly because I'm not sure what that even means, but I doubt that such a thing could seriously interfere with unruh radiation. |
| Jun6-12, 07:45 PM | #43 |
This is discussed in a paper by Wald and Unruh although I'm forgetting the reference right now. |
| Jun6-12, 07:51 PM | #44 |
That was easy, found it: http://prd.aps.org/abstract/PRD/v29/i6/p1047_1
| Jun6-12, 08:03 PM | #45 |
"It is shown in detail for the simple case of a two-level detector how absorption of a Rindler particle corresponds to emission of a Minkowski particle." |
| Jun7-12, 12:48 AM | #46 |
P.S. Yet another question. By the equivalence principle, the Unruh radiation effect implies that an observer that is stationary observer outside a blackhole sees Hawking radiation and observes the black hole evaporate (possibly to nothing in a mini explosion) while a free falling observer would not be able to see the Hawking radiation and would either see no change in the mass of the black hole or would be unable to explain the loss of mass of the black hole. Which position is more accurate? |
| Jun7-12, 12:53 AM | #47 |
Edit: To speculate a bit, I would guess that in the case where a "pre-existing" particle is present, it won't look the same to the inertial observer as it does to the accelerated observer, for reasons similar to why the vacuum state for one is not the vacuum state for the other. Also, I would expect that, once the emitted Minkowski particle collides with the pre-existing particle, the Minkowski particle will no longer be in the state that the Rindler observer thinks is "vacuum"; i.e., it will now be visible to that observer. So I would guess that the Rindler observer's interpretation of events would be that his detector absorbs a particle (so the field is now in the vacuum state); then the pre-existing particle causes a particle-antiparticle pair to pop out of the vacuum (what the Rindler observer "thinks" is the vacuum), one of the pair flies off, while the other is absorbed by the pre-existing particle and changes its state. That's just a guess, though; as I said, I haven't seen any mathematical treatment of this case. |
| Jun7-12, 01:18 AM | #48 |
| Jun7-12, 08:37 AM | #49 |
| Jun8-12, 03:12 AM | #50 |
http://xxx.lanl.gov/abs/gr-qc/0409054 |
| New Reply |
Similar discussions for: Unruh Effect
| Unruh effect = Compton effect ? | Beyond the Standard Model | 2 | ||
| Unruh effect and Gravitons | Beyond the Standard Model | 7 | ||
| Dumb question on Unruh effect | Special & General Relativity | 9 | ||
| What is the 'Unruh Effect'? | General Physics | 13 | ||
| No Unruh effect? | Beyond the Standard Model | 16 | ||
