| New Reply |
Relativity vs competing theories |
Share Thread | Thread Tools |
| Feb7-12, 10:18 AM | #35 |
| Feb7-12, 10:21 AM | #36 |
| Feb7-12, 10:27 AM | #37 |
| Feb7-12, 06:35 PM | #38 |
Instead of assuming that we are stopped in the absolute rest frame, and considering everything else in motion with respect to us, could we assume that if an absolute rest frame were to exist, then we would be in motion with respect to it, as would everything else? Again, we don't need the rest frame, we can just hypothesise that if one were to exist, that we would be in motion relative to it. |
| Feb7-12, 06:52 PM | #39 |
| Feb7-12, 07:09 PM | #40 |
| Feb7-12, 08:12 PM | #41 |
It's no different than Einstein's second postulate that light travels at c in any reference frame. That also has no proof or evidence but neither is there any proof or evidence that denies that it can't happen. It sure seems to me like you're understanding this. I don't see why you keep asking the same questions and getting the same answers. Maybe you could explain why you're struggling with this. |
| Feb8-12, 02:37 AM | #42 |
- http://www.fourmilab.ch/etexts/einstein/specrel/www/ - http://www.bartleby.com/173/7.html - http://www.bartleby.com/173/7.html |
| Feb8-12, 08:27 AM | #43 |
Harald |
| Feb8-12, 06:11 PM | #44 |
| Feb8-12, 11:24 PM | #45 |
Please forgive my continual recourse to the light clock thought experiment, if it seems either naiive or monotonous; it's just that I [personally] find it quite helpful as a visual aid to addressing my understanding, or lack thereof. Essentially, the differences [as I understood them] are:
My understanding of LET is that, if the observer on the train were in a windowless carriage - like Galileo's observer on the ship - they would not be able to determine if they were at absolute rest, so they could not tell if their clock was ticking at the "normal" rate, or if it was actually ticking slower, because they would have nothing to compare it to. If, however, they were able to see the earthbound clock, they would presumably be able to calculate that it was ticking faster (assuming the earth is traveling with a lower velocity relative to the rest frame) I had a more detailed explanation of what I mean typed out, but I wanted to try and make it more concise. I can post that if the above isn't very clear. Again, just to return to the light clock thought experiment, to try and clarify my [lack of] understanding: the tick-tock of a light clock is determined by the distance the photon has to travel in the light clock; under SR this is represented by a line perpendicular to the midpoint of both mirrors. This would be the same as if the clock were at absolute rest. I've been told that this representation of the path of the photon is not based on an assumption, but is something that is borne out by experiment; or from the verification of the second postulate; that it is because the speed of light is constant, regardless of motion relative to the source, that it has to be so, otherwise the observer on the train would measure a slower speed of light. To me it appears as though this is not the case under LET, where, as you mention, we can just consider the train's clock from the absolute rest frame - which would be the same as the observer on the platform's view, in the Einsteinian version. In this case the tick-tock of the trains clock is not simply the perpendicular line between the midpoints of the two mirrors, rather the line as represented by the hypotenuse of a right angled triangle; and this would be as true for the observer on the train as for the observer in the absolute rest frame - even if the observer on the train could not determine that it was so. Hopefully the above makes sense, and if I haven't entirely exhausted your patience, if you could point out anywhere I might be going wrong, I would be very greatful. |
| Feb9-12, 04:19 AM | #46 |
http://en.wikipedia.org/wiki/Kennedy...ike_experiment With such known and future experimental results was dealt with here: http://en.wikisource.org/wiki/Electromagnetic_phenomena Harald |
| Feb9-12, 08:59 AM | #47 |
Hey Harry, thanks for replying. Firstly, can I assume, from the lack of comment, that what I wrote about the reciprocity of contractions and the attributed cause of contractions is accurate?
When I say the treatment of the photon under LET, I mean my understanding as I've outlined above i.e. that the path of the photon is not necessarily the perpendicular line between the midpoints of the two mirrors, but rather the path represented by the hypotenuse of a right angled triangle. |
| Feb9-12, 10:27 AM | #48 |
The easiest way I know to communicate this idea is to think just about relative motion. If A and B are in relative motion, in one FoR, A is assigned a speed of zero and B is assigned a non-zero speed. In another FoR, B is assigned a speed of zero and A is assigned non-zero speed. Do you think that using a different FoR caused A to suddenly start moving? I don't think so, I think with regard to motion, different frames make perfect sense. The same thing applies to length contraction and time dilation. The ones that have motion according to the FoR that you are using are the ones for which lengths and times take on a different meaning. In the early days, Lorentz and others were trying to determine how the mechanics of a clock would cause it to slow down as it traveled through the ether but now we don't worry about that. What we do instead is verify that the laws of physics transform intact under the Lorentz transformation. If they don't, we know they are not valid and we change them until they do. If they do, then we don't have to be concerned about the specific mechanics, it will happen automatically. |
| Feb9-12, 11:06 AM | #49 |
![]() I wasn't sure about what you meant and decided to leave it. [Addendum: I agree with George's clarifications.] However, with my remark in post #38 I meant that I decided from now on to abstain from discussions about a hypothetical competing theory to "relativity theory" as I find it too artificial - surely you notice that "ban" in my latest posts. ![]() Historically there are different interpretations of what started out as the "Lorentz-Einstein theory of relativity" and the idea that Lorentz and Einstein proposed competing theories emerged later. In the early years they promoted the new theory together and their interpretations were not distinguished in presentations and papers. That should hardly be surprising, as physicists tend to focus on the predictions of a theory and not on "metaphysics". |
| Feb9-12, 06:21 PM | #50 |
If we consider both A and B as "objective" observers, which I think we can do because it is a thought "experiment". From A's perspective, he can consider himself at rest and so the instruments in B's reference frame undergo contraction; while B can also consider himself at rest and it is A's instruments that contract, form B's perspective. The instruments will contract by the same amount.That is what I meant by reciprocity. As I understand it, under LET the contractions aren't reciprocal, in this way. If for example we were to have 3 observers: A is in the absolute rest frame; B is at rest on earth; C is on the train; where the train is moving with a higher relative velocity to the rest frame, than the earth. Then A will see the instruments in the other reference frames contract; B will see C's instruments contract but A's will "expand" [just to contrast with "contract"]; while C will see the other instruments [in both reference frames] expand. Does that make sense, or is it way off? |
| Feb9-12, 06:42 PM | #51 |
I presumed it was intentional but I wasn't clear as to what the intention was.I know physicists tend not to focus on the "metaphysics" but scientific theories have "metaphysical" implications, and insofar as physicists are concerned with accurately describing reality they are concerned with metaphysics; of course, where they are not concerned with accurately describing reality, they are not concerned with metaphysics. Given that the differences between [what has been described in this thread as] LET and Einsteinian relativity are effectively metaphysical, it is probably unavoidable to discuss them without discussing the metaphysics. Who knows a certain level of metaphysical consideration could actually facilitate the unification of QM and SR. [QUOTE=harrylin;3754767]Lorentz already answered that: deduced was what Einstein made a postulate. The fundamental equations suggested to Maxwell and followers that light is a wave with propagation constant c in vacuum.[/quote The speed of light being a constant (c) in vacuum, and the speed of light being c regardless of the motion relative to the source, appear to be somewhat different. Has the latter been borne out by experimental evidence, or has it just not been contradicted by experimental evidence? Part of my confusion arises because it seems as though LET has a different "second postulate" than Einsteinian relativity, which also fits the evidence. This leads me to believe there is limited scope for deducing a postulate with respect to the speed of light - would that be correct? Under SR the path of the photon traces a line perpendicular to the two mirrors; while under LET [as I understand it] the photon traces a line as represented by the hypotenuse of a right angled triangle. Under SR, the photon has a strictly vertical velocity component of c, and so the observer would measure the speed of light to be c, relative to the carriage. Under LET, the photon has a velocity of c in the horizontal (or diagonal) direction - due to the motion of the train and the clock - but not a velocity of c in the vertical direction. If the observer can only measure the speed relative to his reference frame he would not measure the speed of light to be c, but some lower value. If both theories equally explain the evidence, then it suggests that the speed of light is not necessarily constant in all directions, regardless of the motion relative to the source. It has been suggested [by others, elsewhere] that the MMX demonstrates that the speed of light is constant in all directions, regardless of the motion relative to the source; however, if the null result of the MMX is equally explained under LET, then this seems to suggest that this isn't the case. Again, hopefully the above makes sense. |
| New Reply |
| Thread Tools | |
Similar Threads for: Relativity vs competing theories
| Why are theories of QM and relativity not possible to combine? | Beyond the Standard Model | 8 | ||
| a book on einstein's theories of relativity | Science Textbook Discussion | 23 | ||
| cosmological relativity theories | General Astronomy | 3 | ||
| Special Relativity at HighSchool, theories against. | Introductory Physics Homework | 17 | ||
| Theories of Relativity: Analogon | General Physics | 5 | ||
