| Thread Closed |
Potential energy question |
Share Thread | Thread Tools |
| Dec21-04, 04:40 PM | #1 |
I just made the following statement regarding two masses, M and m, in orbit about each other.
"Btw, IIRC [and I may not be... I will check], as the potential energy of the gravitational field of M, wrt to m, is converted to kinetic energy in m, the mass of M decreases according Einstein's mass/energy relationship. As m loses kinetic energy to potential energy the mass M increases. This accounts for the energy storage and exchange. Am I screwing this up or does memory serve correctly? It makes sense but that is usually a bad sign.
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec21-04, 05:13 PM | #2 |
Let's assume that you're refering to two bodies in orbit about each other for which the speed of each and the distance between them changes as a function of time. In such a case the kinetic energy and potential energy will change with time and (disgregarding energy carried away in gravitational waves) the total energy of the system will be constant. The proper mass of each body will remain constant. Pete |
| Dec21-04, 05:19 PM | #3 |
In Newtonian orbital mechanics the masses stay constant. The energy shuttles back & forth from kinetic to potential energy based upon a change in radial distances and velocities. Creator ![]() Opps; looks like I stepped over Pete. |
| Dec21-04, 05:40 PM | #4 |
Eeeeek! This stemmed from a question about where the potential energy is stored. What am I forgetting here?
| Dec21-04, 05:41 PM | #5 |
IF you think I am forgetting about the energy exchange between potential and kinetic energy, that's not what I'm saying.
| Dec21-04, 05:55 PM | #6 |
You seem to be using an elementary interpretation of potential energy.
Yes, no? Oh yes, IIRC, If I recall correctly Also, I meant the potential energy of the field at m, not wrt m. |
| Dec21-04, 06:08 PM | #7 |
When I see people use the term "potential energy is located at.." I runaway and hide.
Pete |
| Dec21-04, 06:13 PM | #8 |
U = -GMm/R And yes, it is elementary; it is, as I said, Newtonian mechanics. Creator ![]() (edited to add in neg. sign). |
| Dec21-04, 06:18 PM | #9 |
I think there is a more fundamental interpretation. This is always tough because I used to be relatively certain of what I know and what I don't, but I haven't studied some of this for so long now...scary....
| Dec21-04, 06:21 PM | #10 |
| Dec21-04, 06:33 PM | #11 |
Ivan, your memory is not so bad. Remember the Einstein box? Anyways, it goes like this. Suppose you fire a flash of light with an energy of 13.6ev at a hydrogen atom. This will knock the electron out of orbit and you will be left with a proton and an electron, which collectively have a total mass that is exactly 13.6ev more than a hydrogen atom. This difference is the potential energy residing in the separated particles. If you bring them back together, the reformed hydrogen atom will release this potential energy in another flash of light with an energy of 13.6ev. In the case of gravitational potential energy, the energy used to separate mass m from mass M is stored by both objects. This is, of course, offset by the energy used to move them apart. If you borrow all the energy used from M, its mass will decrease and the mass of m will increase. If you borrow equally from m and M, both will have the same mass after being separated as they did prior to separation. If you steal the energy from say the moon, m and M will both increase in mass while the moon looses mass.
| Dec21-04, 06:56 PM | #12 |
Wheeeewwwwwwww! Thanks Chronos. pmb_phy and Creator scared me for a minute there.
...and as pmb_phy pointed, under GR there is [still] no energy in the field. Correct? |
| Dec21-04, 08:47 PM | #13 |
Recognitions:
I would suggest reading the sci.physics.faq on energy conservation in general relativity located
here To put it as simply as I can, there is a well defined concept of conservation of energy in general relativity which does however require specific boundary conditions ("asymptotically flat space-times"). However, when a system contains significant gravitational energy, it's usually not possible to localize it in GR. (The exception is a static space-time. Planets orbiting each other aren't static, though.). |
| Dec21-04, 09:05 PM | #14 |
If you're asking if gravitational energy has a mass related to it then yes, that's quite true. Pete |
| Dec22-04, 12:08 PM | #15 |
Ivan Seeking "As m loses kinetic energy to potential energy the mass M increases. This accounts for the energy storage and exchange."
Pete "The proper mass of each body will remain constant." Creator "In Newtonian orbital mechanics the masses stay constant" Chronos "....collectively have a total mass that is exactly 13.6ev more than a hydrogen atom. This difference is the potential energy residing in the separated particles" Pete, "If you're asking if gravitational energy has a mass related to it then yes, that's quite true" Confusing isn't it? In Newton and GR the mass of the bodies stays constant. In Newton energy is kept in a separate account, and KE + PE = const. In SR the two accounts appear to merge E = mc2 But physicists like to keep them separate anyway and have invariant particle masses, so that energy has now to be kept in the field. Even if this means in the case of a bound system such as an atom then that field has to store negative energy. In GR particle masses are constant but except in certain static fields energy goes all over the place, it is not locally conserved and the value of a particle's energy cannot be transported from one position to another in the presence of curvature unless there is a time-like killing vector, which generally does not exist. Therefore the great classical separate principles of the conservation of energy and mass were magnificently united by SR only to be discarded by GR, except in some special contrived situations. Perhaps GR needs to be modified to restore the situation? I won't bore you again with my solution! Garth |
| Dec22-04, 03:38 PM | #16 |
Recognitions:
So it is not a question of a body's mass being converted to kinetic energy or stored as potential energy. Its mass, and therefore its gravitation, is constant. Its mass merely oscillates between rest and relativistic mass (in the frame of reference of the centre of mass of the system). AM2 |
| Dec22-04, 04:22 PM | #17 |
Garth |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Potential energy question
| potential energy question | Advanced Physics Homework | 4 | ||
| Question about Potential Energy. | Classical Physics | 2 | ||
| Potential Energy Question | Introductory Physics Homework | 3 | ||
| Potential energy question | General Physics | 8 | ||
| a question regarding Potential Energy | General Physics | 8 | ||
