| New Reply |
magnetic field |
Share Thread | Thread Tools |
| Feb7-12, 10:49 AM | #1 |
magnetic field
There are two hemispheric magnets, both of them have S on the outer surface and N on the inner surface. If I put them together to form a hollow ball, assuming they are so close that no empty space in the interface, what happens to the magnetic field (inside and outside)?
Since magnetic field lines must start from N and end at S, what I think is that the field line will not "come out" from the inner surface any more as it cannot connect to the outer surface of the magnet. So this ball is not longer a magnet, is it right? |
| Feb7-12, 03:30 PM | #2 |
Recognitions:
That arrangement will have a complicated magnetic field. While no net field leaves the ball, there will be field lines leaving at some points and entering at others.
| Feb7-12, 08:42 PM | #3 |
There will also be "magnetic pressure" trying to push the hollow ball apart (as would be felt while trying to push the two halves together). So it will still be a magnet. I'd love to be able to try this.
| Feb7-12, 10:34 PM | #4 |
magnetic field |
| Feb8-12, 10:48 AM | #5 |
Recognitions:
Yes.
| New Reply |
| Tags |
| hemispheric magnet, magnetic field |
| Thread Tools | |
Similar Threads for: magnetic field
| Moving charge in a magnetic field, magnetic-magnetic interaction? | General Physics | 6 | ||
| Electric or magnetic field at point P in presence of dielectric/magnetic material. | Classical Physics | 9 | ||
| Alignment of micro dipoles in magnetic material in external magnetic field. | Classical Physics | 5 | ||
| coils rotating in a magnetic field find maximum emf and magnetic feild strength | Introductory Physics Homework | 1 | ||
| Magnetic induction equation -How does it change in case of a rotating magnetic field? | General Physics | 2 | ||
