Calculating speed of spacetime
  • Context: Graduate
  • Thread starter Thread starter CCatalyst
    Spacetime Speed
The discussion revolves around the concept of calculating the speed of spacetime in relation to gravitomagnetism and its effects on spacetime distortion. Participants explore theoretical aspects of gravitomagnetic fields, their implications for spacetime, and the potential for a gravitomagnetic drive system.
  • Some participants discuss how a gravitomagnetic field is analogous to an electromagnetic field created by moving mass, questioning how to calculate the speed at which spacetime is affected.
  • Others argue that spacetime does not have a velocity, suggesting that the concept may be misunderstood.
  • There is mention of gravitomagnetic waves traveling at the speed of light (c), but uncertainty remains about the implications for spacetime movement.
  • A participant proposes that a spinning ring could distort spacetime differently at its center versus its edges, raising questions about the rate of distortion.
  • Some participants clarify that the gravitomagnetic force affects matter rather than pushing spacetime itself, emphasizing the need for reaction fuel in propulsion systems.
  • Questions arise about the strength of the gravitomagnetic field generated by moving masses and how it varies with distance from the source.
  • There is a discussion about the speed of time and how it relates to observers in motion, with some participants expressing confusion about the concept.
  • Clarifications are made regarding the meaning of "AFAIK" (as far as I know) and the nature of time as a measurement rather than a traveling entity.
Participants express differing views on the concept of spacetime velocity, with some asserting it does not exist while others explore its implications. The discussion remains unresolved regarding the calculations and effects of gravitomagnetism on spacetime.
Limitations include unclear definitions of terms like "velocity of spacetime," and unresolved mathematical steps related to the strength of gravitomagnetic fields and their effects on light.
CCatalyst
I've been reading up on the topic of gravitomagnetism, and how a gravitomagnetic field is created by a particle with mass moving through space the same way how an electromagnetic field is created by a particle with charge moving through space.
Now I have been reading up on this topic, and obviously this would be a good way to warp the contents of spacetime. But I'm a bit confused on one thing. How do you calculate the speed at which the effect causes spacetime to travel? I have been playing around with the equations for days but have been unsuccessful in determining the velocity of spacetime. Can anyone help with this?
Spacetime doesn't have a velocity AFAIK.
I'm not really sure what you mean "the velocity of spacetime." The Maxwell-esque gravitomagnetic equations (which are a weak field approximation of general relativity) can be used to calculate the speed of gravitomagnetic waves, and it turns out they travel at c. I don't know if this is what you had in mind.
Here is what I meant. Since gravity distorts spacetime, how would the a spinning ring through gravitomagnetism cause spacetime to distort? I'm assuming it would cause spacetime to move one way through the center, and the opposite direction outside the edges. The question is how quickly would it cause spacetime to move? Or what is the rate of spacetime distortion with respect to time?
A spinning ring would be a dipole source, and the minimum for gravitational radiation is quadrupole (i.e. a pair of orbiting masses). There is some evidence that gravitational radiation from a pair of orbiting masses travels at c.
Perhaps I should rephrase the question. If a gravitomagnetic drive system, such as one studied by the ESA, were to run at a fixed power, would it keep going faster and faster or would it reach a certian speed as a function of power being fed to the device? Or is it a little of both? And how do I calculate what that is?
You may be thinking of ion propulsion drives, often used for planetary missions. These are not gravitomagnetic. The gravitomagnetic force does not "push spacetime", it pushes matter, so you would still need reaction fuel. And even if you circulated neutron star matter around the ring at relativistic speeds, the reaction force you'd get would be far too small.
I'm not talking about ion engines. Ion engines work by ionizing particles and ejected through screens given an electrical charge that pushes them out the back at a low mass rate but at a high speed.
What I'm talking about is rotating masses that affect gravity. And it's entirely enclosed.
Tell you what. Allow me to rephrase the question again. How much force would be created at a variable distance from the device? That and how much would the effect locally change the speed of light? (I've heard about how gravity affects light. An example of this would be black holes.)
Please provide a reference for this.
Ok, I'll rephrase the question. There is the analogy of how when an electric current creates an electromagnetic field? I need to know the strength of a gravitomagnetic field caused by a moving mass. Such as a stream of matter being spewed from a quasar or something. Als I would like to know how strong the gravitomagnetic field is as a function of the radius from the source.
I'm having a hard time understanding the material. Could you provide a worked example? Such as a given mass, a given speed, a given radius from the moving mass, and how quickly the mass is moving.
It is possible to follow up on CCatalyst’s question about the velocity of spacetime? In particular I wonder what the speed of time is and how we calculate it. I’m thinking of the conclusion derived from different observations and the premise that light is constant, which implies that time for moving observers is slower than time for stationary observers.
Speaking of the speed of time doesn’t sound odd to me if we think one person’s time moves slower than another person’s time.
Also, what does "AFAIK" mean?
its still not a clear question. are you referring to centrifugal force and how it could bend lights speed and direction?
someone please correct me if I am wrong because i hardly know anything about the topics in this forum but...
you got it backwards. it wouldn't be a moving observer if you were experiencing it first hand. time is relative to the first person so to observers, the one with motion is moving through time faster than one who is stationary. obviously for these effects to become apparent youd need to have enough mass to bend spacetime.
there is no speed for time. time is just t and our way of measuring it is through seconds, hours, weeks, years, etc. time does not travel, just like a line, x-y graph or x-y-z graph also don't travel. spacetime can bend but not travel
AFAIK means as far as i know
  • · Replies 35 ·
  • · Replies 29 ·
  • · Replies 21 ·
