Let's suppose that both sequences are convergent
The discussion revolves around the properties of sequences, specifically the relationship between divergent sequences and the product of those sequences. The original poster is trying to understand why the statement that the product of two divergent sequences is also divergent is considered false.
  • The original poster attempts to reason through the implications of convergence and divergence, questioning how the product of divergent sequences can yield a convergent result.
  • Some participants provide counterexamples to illustrate that divergent sequences can produce a convergent product.
  • Others suggest reconsidering the definitions of convergence and divergence in the context of sequences versus series.
Participants are actively exploring different interpretations of the problem, with some providing examples that challenge the original statement. There is a recognition that the original poster's assumptions may not apply, and some clarity is being achieved regarding the nature of divergent sequences.
There is a mention of confusion stemming from the theorem related to convergent series, which states that terms in a convergent series approach zero, highlighting a potential misunderstanding in applying this concept to sequences.
DivGradCurl
Consider the following statement:
If [tex]\left\{ a_n \right\}[/tex] and [tex]\left\{ b_n \right\}[/tex] are divergent, then [tex]\left\{ a_n b_n \right\}[/tex] is divergent.
I need to decide whether it is true or false, and explain why. The real problem is that I checked the answer in my book; it's false, but I don't understand it. Here is what I think:
Let's suppose that both sequences are convergent. Then, it follows that
[tex]\lim _{n\to \infty} a_n \cdot \lim _{n\to \infty} a_n = \lim _{n\to \infty} \left( a_n b_n \right) \tag{1}[/tex]​
But, the truth is that both are divergent. So, [tex]\lim _{n\to \infty} a_n \neq 0[/tex] and [tex]\lim _{n\to \infty} b_n \neq 0[/tex]. If neither is zero, then how can [tex]\lim _{n\to \infty} \left( a_n b_n \right) = 0[/tex] (so that the statement is false)? It doesn't sound reasonable if you consider (1).
Can anybody please help me clarify this?
Thank you very much.
If a sequence is convergent, it doesn't decessarily means it converges towards 0, like you seemed to be implying in your post.
To decide wheter the proposition it's true or false, a simple counter exemple suffice. Consider [itex]a_n = (-1)^n[/itex] and [itex]b_n = (-1)^n[/itex]. These are both divergent series because when n is pair, [itex]a_n = 1[/itex] and when n is odd [itex]a_n = -1[/itex], such that the limit is dependent upon n ==> it is not unique ==> it doesn't exist ==> the sequences diverge. But [itex]a_n b_n = (-1)^{2n} = 1 \ \forall n \in \mathbb{N}[/itex] is a sequence that converges towards 1.
Or take [itex]a_n = (-1)^n[/itex] and [itex]b_n = (-1)^n+1[/itex]. Then [itex]a_n b_n = (-1)^{2n+1} = -1 \ \forall n \in \mathbb{N}[/itex], which converges towards -1.
N.B. But in the case where [itex]a_n[/itex] and [itex]b_n[/itex] are divergent because they increase or decrease without limit (i.e. because their limit is plus or minus infinity), then it is true that [itex]a_n b_n[/itex] is also a divergent sequence.
Oh... I see what you mean. I thought that way because I had in mind the theorem that says that when a series is convergent, the terms go to 0. It doesn't apply in this case, since we only have sequences. Thanks.
I see, so it isn't true in general.
The following is a problem step:
The hypothesis is that both sequences are divergent, not convergent, so this thought does not apply to this question in any useful way.
For example, [itex]a_n=b_n=(-1)^n[/itex] are two divergent sequences, but [itex]\{a_nb_n\}[/itex] is constant, so it clearly converges.
By the way, the theorem about series on indicates that terms in a convergent series go to zero. There are divergent series that go to zero like the harmonic series:
[tex]\sum_{i=1}^{\infty} \frac{1}{i}[/tex]
And, since
[tex]\sum_{i=1}^{\infty} \frac{1}{i^2} = \frac{\pi^2}{6}[/tex]
is convergent, the above is false for series as well as sequences.
