| Thread Closed |
Ten Sheep |
Share Thread | Thread Tools |
| Dec22-04, 04:58 PM | #1 |
Ten Sheep
This problem has me baffled, I decided to put it in the brain teasers because it does not seem to be straight forward
Here is the problem. http://www.whitehouse.gov/kids/math/open/chl_82.html |
| Dec22-04, 05:46 PM | #2 |
You measure from the time the first sheep jumps till the last one does. So there are only 9 'jump intervals' in the ten minute period. Therefore a 'jump interval is 1.111... minutes. There are 54 such intervals in an hour, so the answer they're looking for is 55 (I guess).
| Dec22-04, 06:02 PM | #3 |
Well, the site does say your answer 55 is right, ceptimus. Of course, that assumes that the first sheep jumps immediately, and why would you assume that? If it takes 10 minutes for 10 sheep to jump the fence then each sheep clearly must spend the majority of his jumping time just eating grass or whatever. Why should the first sheep be any different? Unless maybe the starter's gun startles the first sheep into jumping...
| Dec22-04, 06:03 PM | #4 |
Ten Sheep
Or it could be a low-gravity situation so that each sheep actually DOES take a full minute just jumping...
| Dec22-04, 06:09 PM | #5 |
Ouch, I forgot to add 1 at the end
![]() I tried 54, but that was wrong. Then I tried 60, and then I quit. |
| Dec22-04, 07:21 PM | #6 |
I tried to work this problem out several times, but kept falling asleep.
| Dec23-04, 07:23 AM | #7 |
Ceptimus, are you a scientist?
| Dec23-04, 07:24 AM | #8 |
My first answer was 2145,2(8).They said it was wrong.Then i tried "George W.Bush is a d***head".They said "wrong" again.No that tey learnt my IP number,i wonder how much time will pass till one FBI dude will show up at my door asking for explanation.
Daniel. PS.I wonder if Mr.IQ<100 "Man of the Year 2004" could figure out the answer without puttin' those sheep jump...
| Dec23-04, 08:07 AM | #9 |
I had a buddy who lived on a ranch. I spent a weekend on the ranch when I was little. He said watch how stupid these sheep are. He got a bunch of sheep running around the perimeter of a pen. Then he took a broom stick and held it in front of the sheep. the first sheep jumped over the stick, the second jumped over the stick. Then he took the stick away. The third sheep jumped over the spot where the stick used to be, the fourth sheep jumped over the non-existent stick, the fifth jumped etc.
| Dec23-04, 08:53 AM | #10 |
"...kept falling asleep..."
OK, now that's funny. "...watch how stupid these sheep are..." Actually, you could think of that as quite a brilliant trick. Why wait to see danger yourself? Especially when, in a dense pack, you'll never see it in time. Anticipate. There are advantages to living in a pack. |
| Dec23-04, 08:57 AM | #11 |
"...assumes that the first sheep jumps immediately, and why would you assume that?"
1] Because it is counterproductive to begin measuring the duration of an event from any time other than when the event begins. 2] Because you set the sheep in motion, *then* hit the stopwatch when the first one leaps, not the other way around. |
| Dec23-04, 02:57 PM | #12 |
It's like, if an assembly line can produce X products an hour, you don't get to "pick the hour" to fit an extra product into the hour. Or in a human hurdling event, you don't time it from the point when the hurdler clears hurdle #1; you time it from when he starts running. |
| Dec23-04, 03:50 PM | #13 |
| Dec23-04, 04:02 PM | #14 |
It didn't even work that good.
| Dec23-04, 04:16 PM | #15 |
That's why I said, "...the answer they're looking for..." I don't agree that it is the correct answer. |
| Dec23-04, 04:26 PM | #16 |
So they were looking for 55
Also, I agree with you, that was an akwardly worded problem
| Dec23-04, 04:51 PM | #17 |
Another form of the same problem: How long does it take 10 sheep to jump a fence at a rate of one sheep per minute? Lets see – should be start timing when they start walking across the field toward the fence -- or when the first one jumps. Also along the line of: When will the 200th decade end?? 2009 or 2010 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ten Sheep
| Flying Sheep | General Discussion | 3 | ||
| SHEEP symbolic tensor manipulation program | General Physics | 2 | ||
| SHEEP | General Physics | 6 | ||
| Do you have an ugly sheep? | General Discussion | 12 | ||
| how to get SHEEP MACSYMA | General Physics | 2 | ||
