Thread Closed
How physicists handle the idea of Free Will?
Share Thread Thread Tools
Feb9-12, 09:49 AM   #1
I have always been quite curious how physicists reconcile the concept free will with the determinism of physics.
By determinism I mean the one at macroscopic level, because I know that at quantum level most of the things are based on probabilities. So there's no free will for an electron.
But, at macroscopic level, everything seems to have some equation that determines its future, even if that's chaotic and very difficult (for us) to predict. So there's no free will for the Moon, as we'll know its exact position million of years in the future; in the same way, there's no free will for a drop of water falling in a waterfall - it's future is pre-determined, even if it is very difficult for us to calculate that.
Similarly, there's no free will for a computer, given for the same set of inputs it will always produce the same outputs.
So if I'm to believe in physics determinism, I should give up on the concept of free will, because like a computer whatever choice I'm going to make has been pre-determined by my history, genetics, inputs, environment and so forth - even if that choice may be, to our current capabilities, unpredictable, because it would depend on a very complicated equation.
That is very depressing, and as I love physics and much as I love my free will, I just don't think about that. So how do physicists answer that dilemma - is there free will in physics?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb9-12, 09:58 AM   #2
Mentor
What do you mean by 'free will'?
Feb9-12, 10:03 AM   #3
Quote by Doc Al View Post
That's a good question, and I bet every person will have a different answer. I think this one from Merriam-Webster reflects my thinking:
free will (noun)
1. ..
2. freedom of humans to make choices that are not determined by prior causes or by divine intervention
Feb9-12, 10:09 AM   #4
Mentor
Can you give an example of making a choice not determined by prior causes. Not sure what that would mean.
Feb9-12, 10:24 AM   #5
I reckon you don't believe in free will.
That's a perfectly good point of view - nothing wrong in that. I understand you don't need to reconcile that with physics determinism.
Feb9-12, 10:27 AM   #6
Mentor
Quote by fbs7 View Post
Still waiting for an example so I can understand what you mean by the term.
Feb9-12, 10:40 AM   #7
The way I see it, free will is when Joan d'Arc chose to be burned instead of saving herself by reneging her beliefs. The way I see it, it was her choice.
Feb9-12, 10:47 AM   #8
Mentor
Is it possible to choose what you believe? Clearly her beliefs were strong enough so that when she weighed up the possible options to her burning to death was more desirable than condoning her beliefs.
The point being here that when you "make a choice" you unconsciously and consciously weigh up the ramifications of the options. How you judge the options is based on your accumulated life experience which was largely/entirely out of your control. So imagine that Alice is observed her entire life by Bob and that Bob has a team of expert psychologists. If Bob observes Alice presented with a choice he and his team could use the data and knowledge they have to build a predictive model and predict how Alice will make her decision because what she chooses will be based on her judgement which is built from past experience.
Feb9-12, 10:48 AM   #9
Are you sure her actions weren't determined by her past and brain wiring?
Feb9-12, 11:00 AM   #10
So if I write "ABC", then before you read my post it's already pre-determined that you're going to answer "DEF", based on your past experiences, brain wiring, environment, history, etc...?
That is, no quantum processes can modify that, no still-undiscovered factors can influence it, there's nothing else besides working just like a computer - known outputs for known inputs?
Feb9-12, 11:03 AM   #11
Mentor
Yes I don't see why not. My entire personality is a combination of how my biology reacts with my environment over time, what I know and what I can do is also a product of this. Put the two together and no matter what I do there is a reason that has its basis in some past event.
Even if we propose there was some sort of quantum randomness how does that bring back "free will"? If anything that's less free. With regards to the rest yes, the physical brain and it's physical mechanical processes are not only all that we have found they are all that is indicated.
(Also just some advice but you might want to consider asking for the title of this thread to be modified to "How scientists..." and moved to the biology forum. Physics isn't really the discipline you want to study if you are looking into cognition and behaviour)
Feb9-12, 11:28 AM   #12
I think in the context of this question free will is best described as downward causation.
Feb9-12, 11:40 AM   #13
Mentor
Quote by ModusPwnd View Post
What does that mean?
Feb9-12, 11:55 AM   #14
Simply that the question of free will from a physics perspective is essentially (IMO) a question about downward causation. Rejecting the possibility of downward causation is rejecting free will and finding a case of downward causation tentatively leaves free will on the table.
Feb9-12, 11:59 AM   #15
Mentor
And what exactly is "downward causation" and how does it factor into this specifically?
Feb9-12, 11:59 AM   #16
Mentor
What do you mean by 'downward causation'?
Feb9-12, 12:04 PM   #17
Oh, sorry. Downward causation is simply cause and effect working from 'top' level complex processes down to the fundamental 'low' level processes. Physicists generally work under the assumption of reductionism which has been (somewhat) fruitful but at the moment universal reductionism is just an assumption. There is no evidence that all complex phenomenon can be reduced to the physics of the basic constituents (though that is our working hypothesis).
Here is one read about it, http://www.ctnsstars.org/conferences...0causation.pdf
Note that I am not supporting the idea of downward causation in this thread, I am simply casting the notion of Free Will as an issue of downward causation.
Thread Closed
Thread Tools
Similar Threads for: How physicists handle the idea of Free Will?
Thread Forum Replies
Too Hot to Handle? Materials & Chemical Engineering 3
Let's talk about the capitalist idea of 'freedom': free trade Current Events 35
Blog idea - What Physicists Do - Opinions? General Discussion 3
free energy: please "chew and digest" idea General Discussion 6
