Square wave to sine wave conversion
The discussion revolves around the conversion of a square wave signal into a sine wave within the frequency range of 88 to 108 MHz, specifically for use in a digital radio project. Participants explore various methods for achieving this conversion, including circuit suggestions and considerations related to modulation and transmission.
  • Experimental/applied
  • One participant seeks guidance on converting a square wave to a sine wave for a digital radio project, specifying the frequency range and amplitude.
  • Another participant asks for clarification on whether the square wave signal is already available and its amplitude.
  • Concerns are raised about the purity of the sine wave required, including the acceptable level of spurs and whether the carrier will be modulated.
  • A participant suggests two methods for conversion: repeated filtering and double integration, noting the challenges of achieving this at high frequencies.
  • Discussion includes the need for a low pass filter to eliminate harmonics that could interfere with other services.
  • One participant mentions the legality of transmitting signals in the FM band and the importance of low power transmission.
  • Suggestions for integrated circuits (ICs) that could assist in the conversion process are requested, including those with multipliers and local oscillators.
  • Another participant discusses the potential introduction of amplitude modulation (AM) when using double integration and suggests synchronizing a sinusoidal phase-locked loop (PLL) to the square wave.
  • Further clarification is provided regarding the impact of AM on FM transmission, with a specific ratio mentioned that could be manageable by FM receivers.
  • Participants discuss the feasibility of using existing small transmitters that can interface with MP3 players for stable transmission.
Participants express various methods and considerations for converting square waves to sine waves, but no consensus is reached on a single approach or solution. Multiple competing views and techniques are presented, reflecting uncertainty and differing opinions on the best method.
Limitations include the need for clarification on the specific requirements for the sine wave purity, the challenges of high-frequency signal processing, and the legal implications of transmission in the FM band.
sandhiagu
Hello guys i am very new to this forum.
I am doing project in digital radio. can you tell me how to convert square wave into sine wave of frequency range 88 to 108 MHz.
Thanks in advance.pls suggest me a circuit
Perhaps you need to clarify this.
Do you already have a square wave signal that covers this range and you want to turn its output into a sinewave?
What are you using to do this?
What is the amplitude of the square wave?
You also need to clarify how pure a sinewave you need. In other words, how many dB below the carrier must the spurs be?
Will the carrier be modulated?
hello sir thank you for your reply.
I am modulating frequency of square wave by message signal through digital circuits. message signal is stream of bits. I need to convert this square wave into sine wave before transmission since my receiver circuit will accept only sine waves. The frequency of square wave that is to be modulated is in the range of 88-108MHz and its amplitude is 3.3v.
I assume your transmitted power will be low enough to fall under the FCC part 15 for unlicensed transmitters.
There are two ways I can think of to convert a square wave to a sine wave. The first is with repeated filtering. You may need a number high Q RF stages to accomplish this.
The second is with double integration. The first integration will give you a triangle wave and the second will give you something very close to a sine wave. This likely will be difficult to achieve at 88-108 MHz. It may be easier to do at a lower frequency and multiply the frequency up to 88-108 MHz.
At 100 MHz, the difference between a sine wave and a square wave is that the square wave contains harmonics on 300 MHz, 500 MHz, 700 MHz etc.
A receiver on 100 MHz will not be able to tell that there are harmonics on higher frequencies, however such signals will be able to cause interference with other services, such as TV reception.
So, you would need to use a low pass filter which would allow 100 MHz through, but not the higher frequencies.
You also need to know that transmission of any signal on the international FM band is illegal in most countries except for very low powered signals which cannot be heard outside your property.
Thank you so much. I am going go transmit within 1m area only with low power transmitter. Can you please suggest me any IC that contains multiplier with integrated local oscillator.
skeptic2 said:
IThe second is with double integration. The first integration will give you a triangle wave and the second will give you something very close to a sine wave.
That is going to introduce AM on top of the FM.
It might be feasible to synchronize a sinusoidal PLL to the square wave. Alas, I don't have a specific IC in mind.
True, but only at an amount proportional to 150 kHz/100 MHz = 0.15% or -56 dBc, an amount which is easily handled by the limiter in an FM receiver.
There are chips that divide by variable ratios and that also have VHF oscillators in them.
It is possible to make a PLL synthesizer with these, but you need some serious test equipment to do this.
More realistically, you can get small transmitters that take the output of a MP3 player and transmit it to the FM radio in a car. These are not too expensive and they have a digital frequency readout already.
So you can set it to be between FM stations and it is very stable, so it will stay there.
You could try here:
http://s.dealextreme.com/search/fm+transmitter.html?page=1
They even transmit in stereo.
  • · Replies 26 ·
  • · Replies 39 ·
  • · Replies 25 ·
