New Reply
Volumetric flow rate - Help needed
Share Thread Thread Tools
Feb10-12, 10:02 AM   #1
I posted this in the DE forum as well since it is related.
Hi all,
I've got a fairly straight forward problem to solve here regarding flow rate out of a tank with uniform cross-sectional area. I am treating this is a volumetric flow problem since there is assumed to be volume flow out of the tank, and volume flow into the tank.
I have two Qout terms (one out of a hole in the bottom of the tank, and one from fluid consumed by an engine), as well as one Qin term (via a pump feeding fluid into the tank at a constant rate).
Qouthole (Qh) = a*C*sqrt(2*g*z)
Qoutengine (Qe) = constant
Qin (Qi) = constant
NOTE: a = exit hole area
C = energy loss coefficient
g = gravity
z = head height in tank
My DE looks like:
-A*(dh/dt) = Qh - Qi + Qe
Separating the terms and solving for time by integrating h from Hi to Hf and t from 0 to T, I get this...
((a*C)/A)*sqrt(2*g)*(2/3)*((Hf^(3/2))-(Hi^(3/2))) = (1/A)q*t
I combined the Qi and Qe terms early on since they are constants (easier to integrate), therefore, q in the above equation equals Qi-Qf.
The problem is, solving for t eliminates the tank cross-sectional area (A) since it is divided out.
I feel confident with my general equation, but may have made a mistake somewhere in solving for t. Any help would be GREATLY appreciated! Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Thread Tools
Similar Threads for: Volumetric flow rate - Help needed
Thread Forum Replies
Volume flow rate DE - Help needed Differential Equations 3
At what volumetric flow rate will air fill a space vacuum at Earth's STP? General Physics 19
Volumetric flow rate (simple???) Engineering, Comp Sci, & Technology Homework 1
volumetric flow rate Engineering Systems & Design 7
