| New Reply |
3rd and 5th harmonics |
Share Thread | Thread Tools |
| Feb10-12, 12:48 PM | #1 |
An a.c. voltage, V, comprises of a fundamental voltage of 100V rms at a frequency of 120Hz, a third harmonic which is 20% of the fundamental, a 5th harmonic which is 10% of the fundamental and at as phase angle of 1.2 radians lagging. 1. Write down an expression for the voltage waveform. 2. Determine the voltage at 20ms. 2. Relevant equations 3. The attempt at a solution Im not sure if this is right and would appreciate if someone could take a quick look over it please. 1. I have the fundamental (Vrms x √2) at 141.4v at 120Hz making 3rd harmonic (20% of 141.4) = 28.3v at 360Hz and the 5th harmonic (10% of 141.4v) = 14.1v at 600Hz Therefore V=141.1 sin (2∏ft) + 28.3 sin (2∏ft) + 14.1 sin (2∏ft-1.2) 2. Using the equation above and inserting 20ms for "t" I got the following voltages 4.05v + -1.16v(?) + 74.15v = 77.04v Any help would be appreciated thanks |
| Feb12-12, 08:28 AM | #2 |
Mentor
I didn't calculate the 2nd and 3rd terms yet, since your original expression was incorrect. However, the 3rd term has an amplitude of just 14.1V, so no way can you get a contribution of 74.15V from it ![]() Hope that helps. |
| Feb13-12, 03:50 PM | #3 |
Thanks for that
So would it be along the lines of: V=141.1sin(240πt)+28.3sin(720πt)+14.1sin(1200πt-1.2) How im working out the voltages is using above formula, This is how I worked out first section but pretty sure im going around this the wrong way 141.1sin = .268 240 x π x 0.02 = 15.08 .268 x 15.08 = 4.04v |
| Feb13-12, 06:27 PM | #4 |
Mentor
3rd and 5th harmonics![]() 1. Evaluate (240πt) = 240 x π x 0.02 = 15.08, as you did. 2. Take the sine of that result, 15.08, but first be sure that your calculator is in radians (not degrees) mode. 3. Multiply the result of Step 2 by 141.1 |
| New Reply |
| Thread Tools | |
Similar Threads for: 3rd and 5th harmonics
| Harmonics is one of those things that few understand....especially | Electrical Engineering | 22 | ||
| Harmonics | Introductory Physics Homework | 1 | ||
| Odd harmonics | Electrical Engineering | 5 | ||
| Harmonics | General Physics | 12 | ||
