Question on Function: y=3x^2 -1/x^3
  • Thread starter Thread starter majinknight
    Function
The discussion focuses on analyzing the function y=(3x^2 - 1)/x^3. Key findings include that the function has no y-intercept due to a vertical asymptote at x=0, while the x-intercepts are located at x=±√(1/3). The horizontal asymptote is established at y=0. The function is increasing on the intervals (-1, 1) and decreasing on (-∞, -1) and (1, ∞). Local extrema occur at (-1, -2) for a minimum and (1, 2) for a maximum, with points of inflection at x=±√2.
  • Understanding of polynomial functions and their properties
  • Knowledge of limits and asymptotic behavior
  • Familiarity with derivatives and their applications in finding extrema
  • Ability to analyze concavity and points of inflection
  • Study the application of the First Derivative Test for identifying local extrema
  • Learn about the Second Derivative Test for determining concavity
  • Explore the concept of asymptotes in rational functions
  • Investigate the graphical behavior of polynomial functions and their transformations
Students and educators in calculus, mathematicians analyzing polynomial behavior, and anyone interested in function graphing and analysis.
majinknight
Hi i was wondering if someone could check to see if i did this question correctly.
The question is: For the function y=3x^2 -1/x^3
a)Determine the x-intercept(s) and y-intercept(s)
b)Determine any asymptotes
c)Find the intervals of increase and decrease
d)Final all maximums and minimums
e)Find the interval(s) where the graph is concave upward and concave downward
f)Find any points of inflection
a) when x=0, y=-1/0, so the y-intercept is not in the real number plane.
when y=0, x^2=1/3, so the x-intercepts are positive 1/square root of 3 and negitive 1/square root 3.
b)someone: x^3=0
x=0, there fore a someone asymptote at x=0.
limit as x->0 from the left -1/small negitive number= positive infinity(shoots upward).
limit as x->0 from the right -1/small positive number=negitive infinity (shoots downward).
Horizontal: lim as x->infinity from the right 3x^2/x^3 =lim as x-> infinity from the right 3/x =0.
lim as x->infinity from the left =3/x =0
Therefore there is a horizontal asymptote at y=0.
For very large positive values of x the function approaches the horizontal asymptote from above. For very "large" negitive values of x the function approaches the horizontal asymptote from below.
Slant: There is no slant asymptote.
c)d) dy/dx= 6(x^3)- (3x^2 -1)(3x^2) / x^6
=-3x^4 + 3x^2 / x^6
=-3(x^2 -1) / x^4
0=x^2 - 1
x= positive and negitive one
So when i make my chart i get that a local minimum occurs at (-1, -2) and a local maximum at (1,2). The function is increasing when -1<x<1. The function is decreasing when x<-1 and x>1.
e)f) second derivative= (-12x^3 + 6x)(x^6) - (-3x^4 +3x^2)(6x^5) / x^12
=6x^9 - 12x^7 / x^12
=6(x^2 - 2) / x^5
0=x^2 - 2
x= positive and negitive square root of 2
So when i do my chart i get that the function is concave down when x<- square root 2 or when negitive square root 2<x< square root 2. The function is concave up when x> square root two. A point of inflection is at x=square root two and y= 5/ 2 square root 2.
I hope that was not too confusing the way i put it, and if anyone can see a mistake i wouldn't very much appreciate it.
Looks pretty good to me!
I assume that you MEAN y= (3x2-1)/x3 and NOT y= (3x2)- (1/x3).
Yes, because 1/x3 is not defined at x= 0, neither is y: the graph has no y-intercept but does have a vertical asymptote at x= 0.
y= 0= (3x2-1)/x3 is the same as 3x2-1= 0 so
x= +/- &radic;(1/3) are the two x-intercepts.
Since the denominator has a higher degree than the numerator, there is a horizontal asymptote at y= 3 and no slant asymptote.
y'= ((6x)(x3)- (3x2-1)(3x2))/x6
= (6x4- 9x4- 3x2)/x6
which will be positive as long as -3x4- 3x2= -3x2(x2- 1) is positive which is the same as x2- 1 negative. Yes, that will be 0 at x= 1 or -1, It will be positive (and so y' is negative) for x< -1, y' will be positive for -1< x< 0. It stays positive for 0< x< 1, and is negative for x> 1.
That is: y is decreasing for x< -1, has a local minimum at x= -1 (when y= -2). increasing from -2 to infinity for -1< x< 0, increasing from -infinity to 2 for 0< x< 1, has a local maximum at x= 1 (when y= -2) and then decreases for x> 1.
The second derivative is just as you say. It is 0 at x= +/- &radic;(2), is negative for x< -&radic;(2), positive for -&radic;(2)< x< 0, negative for 0< x< &radic;(2), positive for x> &radic;(2).
That is: there are inflection points at +/- &radic;(2), the graph is convex downward for x< -&radic;(2), convex upward for -&radic;(2)< x< 0, convex downward for 0< x< &radic;(2), and convex upward for x> &radic;(2).
Alright Thanks!
  • · Replies 40 ·
  • · Replies 38 ·
