Projectile Motion - find initial velocity, flight time and max height
The discussion focuses on solving a projectile motion problem involving a golf ball shot from a height of 6.5 ft at a 45° angle. The initial velocity was calculated to be 10.82 m/s using the range formula R = (v0cosθ)*[(2v0sinθ)/g]. The flight time was determined to be approximately 23.9 seconds, with additional calculations needed to find the time for the ball to drop the remaining height. The maximum height reached by the ball was computed as 4.96 m.
  • Understanding of projectile motion equations
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with unit conversions (imperial to metric)
  • Basic algebra for solving quadratic equations
  • Study the derivation of the range formula for projectile motion
  • Learn about the effects of air resistance on projectile motion
  • Explore advanced projectile motion problems involving varying launch angles
  • Investigate the use of simulation tools for visualizing projectile trajectories
Students studying physics, educators teaching projectile motion concepts, and anyone interested in applying mathematical principles to real-world scenarios involving motion.
kgal
a golf ball is shot from a height of 6.5 ft above the ground at an angle of 45° above the horizontal. The ball lands 39 ft and 3 inches downfield. Assuming ideal projectile motion find:
a. Initial velocity
b. flight time
c. maximum height
r = [(v0*cosθ)t ]i + ((v0*sinθ)t - 1/5gt^2)j.
I have attached my work (problem 5) but can't seem to know if it correct. I have converted all of my units to metric because gravity is know as 9.8 m/s^2.
kgal,
From what I can gather, you don't have enough information given to you to solve for velocity, time of flight and maximum height directly. Try drawing what you see. The best method I use to solve projectile motion problems is to split the problem up into two parts - the object rising, & then falling.
Also, I can't see your work.
I used the definition of range to solve for initial velocity:
a.R = (v0cosθ)*[(2v0sinθ)/g]
solved for v0 = sqrt (Rg / 2cosθsinθ) = 10.82 m/s.
b. I split the problem into two pieces, the time it takes the ball to reach the horizontal
t1 = 2v0sinθ / g = 23.9 s
Then got stuck on finding out the time it took the ball to drop the remaining 1.98 m...
I tried finding t2 by using r = (v0cos45)t + (v0sin45t - 1/2 gt^2) and solve for t, but got to the point where t was a quadratic equation with 2 answers, t = 3.1 or 0.13 seconds...
c. y max = y0 + (v0sinθ) ^2 / 2g = 4.96 m
