Euclidean geometry and complex plane
The discussion explores the connections between Euclidean geometry and the complex plane, including concepts such as angle preservation, distance, Möbius transformations, isometries, and the representation of hyperbolic geometry using complex numbers.
  • One participant requests a description of how Euclidean geometry relates to the complex plane, mentioning angles, distance, and transformations.
  • Another participant suggests reading "Visual Complex Analysis" by Needham for intuitive connections between complex analysis and geometry.
  • It is noted that multiplying complex numbers results in scaling and rotation, while adding them leads to translation, allowing for dilation of similar figures.
  • A model for the hyperbolic plane is mentioned, where the unit disc in the complex plane is used, and Möbius transformations that map this disc to itself correspond to rigid motions in hyperbolic geometry.
  • One participant describes that maps defined by the formula [az+b]/[cz+d] with real a, b, c, d and ad-bc > 0 represent hyperbolic isometries, although they express uncertainty about this claim.
  • Another participant reiterates the previous point about hyperbolic isometries and clarifies that they are referring to the disk model of complex numbers with modulus less than 1, contrasting it with the upper-half plane model mentioned by another participant.
Participants express various viewpoints on the connections between Euclidean and hyperbolic geometries through complex numbers, with some overlapping ideas but no consensus on the details or implications of these relationships.
There are limitations in the discussion regarding the assumptions made about the properties of transformations and the specific models of hyperbolic geometry being referenced, which may depend on definitions and interpretations.
GcSanchez05
Can someone please describe to me how Euclidean Geometry is connected to the complex plane? Angles preservations, distance, Mobius Transformations, isometries, anything would be nice.
Also, how can hyperbolic geometry be described with complex numbers?
Perhaps you should read a good complex analysis book. Try to read "visual complex analysis" by Needham. A very easy book, but with a lot of intuition and connections to geometry.
Multiplying one complex number by another scales it and rotates it. Adding complex numbers give you translation. So, complex numbers can give you any dilation. So, if two figures are the similar, you can get from one to the other by multiplying and adding complex numbers to it.
There's a model for the hyperbolic plane which is the unit disc in the complex plane. Mobius transformations that map the unit disc to itself act as the rigid motions of the hyperbolic plane.
representing the hyperbolic plane by complex numbers z with real part > 0, one obtains that maps defined by [az+b]/[cz+d/ with a,b,c,d real and ad-bc >0, are exactly the hyperbolic isometries. I think. oops that's what the previous post said.
I referred to the complex numbers of modulus less than 1. That's the disk model.
Mathwonk is referring to the upper-half plane model, which is an equivalent way to think about it.
  • · Replies 19 ·
