Equation of motion via Euler-Lagrange equation
The problem involves a bead of mass m sliding along a parabolic wire in a gravitational field. The participants discuss deriving the Lagrangian and the equation of motion using the Euler-Lagrange equation, focusing on the implications of the motion's characteristics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the derivation of the Lagrangian and the equation of motion, with some expressing concerns about the complexity of the resulting differential equation. There are discussions on small oscillations and the stability of equilibrium points based on the sign of A.
The discussion is ongoing, with participants providing insights into the nature of the motion and the stability of the equilibrium. Some have offered guidance on approximating the behavior of the system under certain conditions, while others are questioning the assumptions made regarding the small oscillations and the implications of A being positive or negative.
Participants note that the analysis of the motion is constrained by the assumptions made about small displacements and the behavior of the system when A is negative, which raises questions about the applicability of their methods in those scenarios.
fluidistic
A bead of mass m slides without friction along a wire which has the shape of a parabola y=Ax² with axis vertical in the Earth's gravitational field g.
a)Find the Lagrangian, taking as generalized coordinate the horizontal displacement x.
b)Write down the Lagrange's equation of motion.
Solved the problem.
a)[itex]L=\frac{m\dot x ^2}{2}(1+4A^2 x^2)-mgAx^2[/itex].
b)[itex]\ddot x (1+4A^2x^2 )-8A^2 \dot x ^2 x +2gAx=0[/itex].
For the fun of it, I wanted to get some information about the motion of the particle, by looking at either small oscilations or by solving the equation of motion.
However:
1)For small oscillations I'd need to approximate the potential energy function by a quadratic function but it's already done so I'm "lucky" on that part. This is supposed to make the equation of motion more friendly.
2)I'm currently self studying mathematical methods in physics and I must say that the equation of motion equation looks really terrible! It's non linear and of degree two.
So I was wondering if I could either solve this differential equation via some method or at least get some info about the behaviour of the motion. Using intuition the motion must be periodic, but I find nothing more than this. Any help is appreciated.
Check the minus sign in front of the second term.
You can find the frequency of small oscillations assuming that x and dx/dt are small, so ignoring the squared terms.
The system is conservative, you can find the relation between x (or y) and dx/dt for a given energy, and determine the maximum displacement from equilibrium or the maximum speed. ehild
Wow thanks a lot.
The differential equation reduces to [itex]\ddot x +2gAx=0 \Rightarrow x(t) \approx A \cos (\sqrt{2gA}x)+B\sin (\sqrt{2gA}x)[/itex] that is, if A is greater than 0.
P.S.:thanks for spotting my sign error.
If A is negative, x=0 is unstable equilibrium. There will not be oscillations, the bead will just slide down along the parabola if displaced from x=0.
ehild
ehild
I understand this with intuition, however how could I "prove" it mathematically or at least see it?
If I still consider [itex]\ddot x +2gAx=0[/itex], this would give [itex]x(t)=Ce^{\sqrt {-2gA}x }+De^{-\sqrt {-2gA}x }[/itex]. I know that this function diverges when x tends to either positive or negative infinite. However this DE was built under the assumption that [itex]x\approx 0[/itex], therefore I do not think it is well suited to study the behaviour of the particle for great |x|.
x=0 is a solution of the original differential equation. If both x and xdot are small, the differential equation is like Hook's Law mx'' = -2mgAx, and the force is opposite to the displacement when A>0. The displaced particle oscillates around the equilibrium point.
If A<0, mx" = 2mg|A|x, the force is in the same direction as the displacement, the displaced particle will move away from equilibrium.
ehild
fluidistic said:
##x(t) \approx A \cos (\sqrt{2gA}x)+B\sin (\sqrt{2gA}x)##
fluidistic said:
##x(t)=Ce^{\sqrt {-2gA}x }+De^{-\sqrt {-2gA}x }##
The x in the argument of the sine and cosine and in the exponents should be t.
Of course, you are right!:smile: I did not notice :blushing:.
ehild
