What is the Simplification of a Boolean Function Using Karnaugh Maps?
The discussion revolves around the simplification of a Boolean function using Karnaugh maps. Participants engage in various aspects of the problem, including constructing truth tables, presenting functions via Karnaugh maps, and expressing functions with minimal literals. The conversation includes attempts at solutions and critiques of each other's work.
  • Homework-related
  • One participant presents a Boolean function and requests feedback on their truth table and Karnaugh map.
  • Another participant points out unnecessary duplication in the gate arrangement and questions the accuracy of the proposed equation relative to the truth table.
  • A different participant suggests factoring out terms in the equation and proposes an algebraic reduction.
  • Further contributions discuss the simplification of terms using basic logic relations, including the "Or everything" rule and its implications.
  • Some participants express uncertainty about the validity of certain simplification rules and their applicability in the context of their homework.
  • There are corrections and clarifications regarding the use of symbols and notation, particularly concerning "don't care" states.
  • One participant introduces an alternative method for simplification by grouping terms on the Karnaugh map.
Participants express differing views on the correctness of the proposed equations and their alignment with the truth table. Some assert that the equations match, while others challenge this assertion. The discussion remains unresolved regarding the best approach to simplification and the application of certain rules.
There are limitations in the discussion regarding the assumptions made about the rules of Boolean algebra and the specific definitions used by the participants. The conversation reflects varying levels of understanding and familiarity with Karnaugh maps and truth tables.
Students and individuals interested in Boolean algebra, logic design, and simplification techniques using Karnaugh maps may find this discussion beneficial.
Femme_physics
Given the function:
http://img26.imageshack.us/img26/9718/elel0.jpg
A) Write the truth table of the function F (A, B, C, D)
B) Present the function F (A, B, C, D) via Karnaugh Map
C) Express the function F as the sum of multiplications with minimum literals
D) Realize the minimized function F via logic gates
I just want to see if I got it right :)
http://img84.imageshack.us/img84/1940/elel1.jpg
http://img577.imageshack.us/img577/1851/elel2.jpg
See your gate arrangement--you have used two NOT gates to twice produce B'. This is unnecessary duplication.
I can't say much about your Karnaugh map, I need to revise that topic myself. :( But I can see that your equation F= AB + B'C + B'C'D' does not match your truth table. Isn't it supposed to??
let's take as correct, your equation F= AB + B'C + B'C'D'
take out as a factor B' --> F = AB + B'(C + C'D')
consider that last term, B'(C + C'D')
when C is true, the bracketed term evaluates as true
when C is false, the bracketed term evaluates as D
so I think there should be some algebra reduction that allows you to make this
F = AB + B'(C + D')
Here's how to go about demonstrating this. After you've been shown once, you'll probably be able to figure it out for yourself thereafter.
let's focus on the term in brackets,
C + ¬C¬D
EDITED:
Consider two basic logic relations:
you can OR anything with TRUE and it's still TRUE
you can AND anything with TRUE and it doesn't change its value
= C ( 1 + ¬D) + ¬C¬D
remove the brackets
= C + C¬D + ¬C¬D
take out a common factor ¬D
= C + ¬D (C + ¬C)
what's in brackets evaluates as always TRUE, so simplifies to
= C + ¬D
remove the brackets
= C + C¬D + ¬C¬D
I never heard this "Or everything" rule in our Boolean algebra. Could our teacher only want us to use the basic list he gave us?
Point taken.
I don't know how to relate truth tables to functions, only functions to Karnaugh Maps and Karnaugh Maps to truth tables. Is it even possible?
I believe that expression does match the truth table.
Your truth table is fine, your Karnaugh table is fine, your function is fine and your circuit is fine. :smile:Btw, you can construct a truth table from a function.
Just start with every combination of A, B, C, and D, which you already have in your current truth table.
If you want, introduce a couple of intermediary results.
Then calculate the result of the function for each combination of A, B, C, and D.
Which basic list did he give you?
It should include that (1 + a) is always true, that is, it is equal to 1.
Btw, can't you put in a drawing of something? Anything? A beetle would do. :wink:
Oops, oops, oops! :redface: :redface: I left out half the explanation in that step.
I meant to also add:
You can AND anything with TRUE and you don't change its value.
Sorry for the oversight. :cry:
I meant to type AND. You can AND anything with TRUE and you don't change its value.
Sorry, now you are going to have to go through the process of unlearning from my typo! I hate that. :cry:
Uhh :rolleyes:... where's the typo?
I like Serena said:
where's the typo?
Fixed now.
I overlooked the distinction between Ø and O so was just a little puzzled. Now I recognize you used Ø for your "don't care" states. So all is correct.
F = AB + B'(C + D')
⇔ F = AB + B'C + B'D'
F = AB + B'(C + D')
:) Thank you!
The simplification in the equation could have also been obtained by grouping the four corners on the Karnaugh map instead of just boxes 0 and 8.
I didn't see anyone else mention it, so I thought I would throw that out there :smile:
