Register to reply
Relationship between wavenumber and angular frequency. + Brillouin zone,stop band
by DoctorDeath64
Tags: brilliouin, dispersion, stop-band, wavenumber
Share this thread:
DoctorDeath64
#1
Feb14-12, 11:22 AM
P: 2
If we take a 1D uniform lattice I understand that we can derive a difference equation after using Hookes law and Newtons 2nd law as seen in the section labelled (Scalar wave equation in one space dimension, Derivation of the wave equation, From Hooke's law) in the link below.
http://en.wikipedia.org/wiki/Wave_equation
We assume that the displacement of a mass positioned at point x, is y(x)=exp[i(kx-wt)], therefore in the discrete lattice we obtain the relationship y(n+1)=exp[ika]y(n), where the spacing of between lattice points is a. By substituting the above relationship and the time dependence into the difference equation we obtain a dispersion relation. The difference equations have position varying, how would we introduce a variation of time ?
So I am wondering what does this represent ? Is it that each point on the curve corresponds to a vibration value and a wavenumber, so that when the perfect lattice has a particular wavelength (i.e. wavenumber), all the masses vibrate at a particular frequency and vice versa?
What if I was to introduce a defect ! Then the dispersion relation would no longer hold, so you may get some points in the stop-band. Does this mean if I vibrate the lattice at a localised vibrational frequency that lies in the stop band, that the wavelength will be a specific value and the displacements will decay from the point of the defect ?
A stop-band is a range of wavenumbers at a particular frequency, what does this mean ? Does this mean , if the lattice vibrates at a frequency lying in the stop band that no waves will propagate through the lattice regardless of wavelength ?
Also they say at the edge of the Brillouin zone, standing waves occur where no energy is propagated, therefore the group velocity=0. Surely if no wave propagates through the lattice, the phase velocity is also 0 ? But in the dispersion curve you can select a value k=pi/a and w>0 for the uniform lattice, which is at the edge of the Brilliouin zone, but the phase velocity=w/k which doesn't equal zero ? Therefore the lattice propagates in time ?
Sorry about the long post, I'm just v. confused. Any help would be much appreciated.
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
'Squid skin' metamaterials project yields vivid color display
Scientists control surface tension to manipulate liquid metals (w/ Video)
Register to reply
Related Discussions
First Brillouin zone Atomic, Solid State, Comp. Physics 2
1st Brillouin zone Advanced Physics Homework 0
Brillouin zone Advanced Physics Homework 3
Brillouin Zone of BCC lattice? Advanced Physics Homework 3
Why only first brillouin zone? Atomic, Solid State, Comp. Physics 2
