Solve Simple Trig Question: Sin x = √3 * Cos X
  • Thread starter Thread starter kscplay
    Trig
The problem involves solving the equation -sin x = √3 * cos x for x in the interval [0, 2π]. Participants are exploring the implications of squaring both sides of the equation and the potential introduction of extraneous solutions.
  • Participants discuss the method of squaring both sides and the resulting factorization, questioning whether this introduces extraneous solutions. There is also mention of checking each solution to determine validity.
The discussion is active, with participants offering different perspectives on how to handle the solutions derived from squaring the equation. Some suggest that only certain solutions may be valid within the specified interval, while others propose alternative methods for solving the equation.
Participants note the constraint of the interval [0, 2π] and the implications this has on the solutions, particularly regarding the rejection of negative answers.
kscplay
-sin x = √3 * cos x
where x is [0,2π]
Would it be wrong to square both sides and then factor?
sin2 x = 3cos2 x
1-cos2 x = 3cos2 x
0= 4cos2 x - 1
0 = (2cos x -1)(2cos x + 1)
Now I solve the factors (2 solutions for each)
Since I've squared both sides, haven't I introduced extra solutions that are not part of the original problem? Will all 4 resulting solutions be correct? Thanks.
Well, when you square root something, you will get a positive and a negative answer, which you already know. Since you defined x as [0,2π], there are no negative numbers in that interval. Therefore, you may disregard the negative answers for this interval, which should leave you with two answers.
hi kscplay! :smile:
kscplay said:
-sin x = √3 * cos x
where x is [0,2π]
yes, since you will also be finding the solutions to sin x = √3 * cos x
the same x can't be a solution to both (unless sinx = 0, of course)
i think the only way to decide which solutions to reject is to actually check each one :wink:
But the simplest way to solve that equation is to divide both sides by -cos(x):
[tex]\frac{sin(x)}{cos(x)}= tan(x)= -\sqrt{3}[/tex]
