Thread Closed
A little inverse help cube root
Share Thread Thread Tools
Dec25-04, 08:41 PM   #1
find the inverse of f(x)=3sqrt(x+2) -7 x>=-2
I got this far (x+7)=3sqrt(y+2)
I dont know how to get rid of the cube root someone help plz
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Dec25-04, 08:49 PM   #2
Quote by aisha
just cube both sides of the equation....
Dec25-04, 08:57 PM   #3
therefore is the inverse of my equation f^-1(x)=(x+7)^(3)-2 ?
Dec25-04, 09:03 PM   #4
Yup.....................
Dec25-04, 09:07 PM   #5
it doesnt look anything like the inverse when plugged into the graphing calculator into y= and compared to DrawInv
Dec25-04, 09:31 PM   #6
I tried again now my answer is
[(x+7)^3] -2
_________
27
Is this correct? OR totally wrong?
Dec25-04, 10:47 PM   #7
Is that 3 * cube root of (x + 2)
or just cube root of (x + 2)??
Dec26-04, 02:25 AM   #8
Recognitions:
Homework Helper Homework Help
Quote by aisha
This is really curious.She's posted 196 times,yet she hasn't had the time to learn how to edit the formulas in 'tex'.
If your initial function was:
[tex] f_{1}(x)=\sqrt[3]{x+2}-7 [/tex]
,then the inverse is found simply:
[tex] f_{1}^{-1}(x)=(x+7)^{3}-2 [/tex].
[tex] f_{2}(x)=3\sqrt[3]{x+2}-7 [/tex]
,then the inverse is easily found to be
[tex] f_{2}^{-1}(x)=\frac{(x+7)^{3}}{27}-2[/tex]
The curious part is that i don't have any idea "which is which",as you posted both answers as 'correct'.Obviously only one is.
In the end i'd like to ask you in a very polite way to sacrifice some of your spare time and read the .pdf document which explains you how you can edit your mathematical formulas in 'tex'.
Daniel.
PS.Isn't it a little weird to you as well that on Christmas Evening you chose mathematics as a 'date'??
Dec26-04, 07:06 AM   #9
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
By the way- the notation "3 sqrt(x)" to mean "cube root" really steams me. It makes it look like you don't know the difference between "cube root" and "square root". Even if you refuse to use [itex]^3\sqrt{x}[/itex] or 3√(x), you could at least write "cbrt(x)" or "3rdrt(x)".
Dec27-04, 11:44 PM   #10
Ur right I really dont have time to read the txt, but when I do have I time I will for sure. The question is 3 * the square root of (x+2) subtract 7
(7 is not under the square root). And yes I do know the difference between cube root and square root.
I got the previous answer because I was told to cube both sides of the equation to get rid of the square root, but I think I was supposed to square both sides of the equation to get rid of the square root.
So is the answer
(x+7)^(2) -2
Dec28-04, 04:08 AM   #11
Recognitions:
Yes,this time it's the good answer. One request,though,pleeaeaeaeaeaeaeaeaeaeaeaeaeaeeaeaeaeaeeaeaeaeaeaeaserea d that file which explains the tex editing language.U might be able to have an adjustable fraction line,not a bunch of minuses...
Daniel.
Dec28-04, 11:20 AM   #12
Recognitions:
Quote by dextercioby
What's wrong with that? I never get any dates, either. Of course, in my case, the reason is obvious.
Thread Closed
Thread Tools
Similar Threads for: A little inverse help cube root
Thread Forum Replies
Equilibrium problem involving cube root Biology, Chemistry & Other Homework 5
Proving that cube root 7 is irrational Linear & Abstract Algebra 4
2-Body inverse cube problem Introductory Physics Homework 0
Inverse-Cube Gravity General Physics 0
Limit with cube and fourth root Calculus 5
