New Reply
Hong-Ou-Mandel effect
Share Thread
Feb20-12, 04:11 PM   #18
Recognitions:
Quote by phonon44145
But in most standard situations a wave function is defined in terms of amplitudes of possible experimental outcomes. So shouldn't this be true for multi-photon states as well?
Sure, probability amplitudes just work fine. However, these just give you probabilities for processes and outcomes of measurements, but no eigenstates.
Suppose we have a bi-photon |2V,0H> i.e. both photons are vertically polarized, and none is polarized horizontally. Can Quantum Optics predict the amplitude of all 4 possible pairs of outcomes RR, LL, RL, LR if one measures both photons in the same (e.g. circular) basis?
Yes, sure. Outcomes of measurements are no problems.
Quote by phonon44145 View Post
I don't see how one can avoid that conclusion (unless one claims that the two photons in |2> form an entangled pair[...].
Just one more issue I just noticed where I am not sure whether the point is clear or not. The photons in a Fock state are not entangled, but that does not mean that they are statistically independent. Even photons in classical states are not necessarily statistically independent.
Feb20-12, 04:28 PM   #19
Quote by Cthugha View Post
Just for curiosity, what are those probabilities equal to? Are they 25% each as one would expect if the photons were totally independent?
I think I can understand the bunching of photons (at least in a thermal source) and antibunching (e.g. resonance fluorescence) and can see that it does not involve any entanglement. I just can't see what would cause such behavior in a Fock state (whether single-mode or multimode).
Feb20-12, 04:39 PM   #20
Recognitions:
That may depend on how you measure it. However, a "simple" and straightforward measurement would typically give classically expected values.
Hmm, but the case of a general Fock state is not that different from resonance fluorescence. Resonance fluorescence gives you the n=1 Fock state and g2=g3=...=gn=0. The n=2 Fock state will give you g2=0.5 and g3=...=gn=0. The n=3 Fock state will give you g2=0.6666666, g3=2/9, g4=0,...gn=0 and so on.
There is not really a conceptual difference between resonance fluorescence and Fock states of higher photon number.
Feb20-12, 05:13 PM   #21
Then can we write |2V,0H> biphoton state in an orthogonal basis according to
|2V,0H> = 1*|2V,0H> + 0*|1V,1H> + 0*|0V,2H>
and
|2V,0H> = (1/2) * |2R,0L> + (1/sqrt 2) * |1R,1L> + (1/2) * |0R, 2L>
so that light will behave "classically"? Also, by "simple and straightforward" you mean ordinary von Neumann measurements?
New Reply
Similar discussions for: Hong-Ou-Mandel effect
Thread Forum Replies
Textbook Recommendation: Mandel-Paule Algorithm General Math 0
The celebrated Hong-Ou-Mandel interferometric effect Advanced Physics Homework 1
Compton Scattering Using Mandel-Stam Variables Advanced Physics Homework 1
what to do in hong kong? General Discussion 3
Mandel & Faster than Light Communication ? Quantum Physics 58
