Math geniuses: Design a function that gives this output
  • Context: Undergrad
  • Thread starter Thread starter Evil Robot
    Design Function Output
The discussion revolves around designing a function that returns three positive integers {a, b, c} such that their product equals a given positive integer n, while minimizing the variance of the set and ensuring a >= b >= c. The conversation explores various mathematical approaches, algorithms, and properties related to this problem.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants suggest that a brute-force solution exists, but a more mathematical approach would be preferable.
  • One participant proposes reducing the problem to combinatorially grouping the prime factors of n to minimize the difference between the chosen factors and the cube root of n.
  • Another participant introduces a recursive approach to find two integers {a, b} such that a*b=n, minimizing variance and ensuring a >= b.
  • Several participants note patterns in the outputs for prime numbers and perfect squares, suggesting that the first value returned by f is the prime itself or the square root, respectively.
  • One participant mentions using a dustbin packing algorithm to distribute factors close to the cube root of n when there are more than three factors.
  • Another participant describes a simple algorithm that involves reducing n to its prime factors and adjusting them to ensure three factors are returned.
  • Some participants express uncertainty about the effectiveness of their proposed algorithms, indicating that they may only work in certain cases.
  • Questions arise regarding the efficiency and polynomial nature of algorithms for prime factoring and dustbin packing.
Participants express various approaches and ideas, but there is no consensus on a single method or solution. Multiple competing views and uncertainties remain regarding the best way to tackle the problem.
Participants highlight limitations in their proposed methods, including dependencies on the number of prime factors and unresolved mathematical steps in their reasoning.
Evil Robot
A general algorithm works too.
Given: a positive integer n
Return: three positive integers {a,b,c} such that a*b*c=n, the variance of {a,b,c} is minimized, and a>=b>=c.
The return might also be understood as "give the (integer) dimensions of the cubiest cuboid of volume n".
I suspect there is only one possible return for each n, though I suppose I don't have any particular reason to guess that.
While a brute-force style solution is obvious, a mathier solution would be more fun.
Examples (if I'm not mistaken):
f(1) = {1,1,1}
f(2) = {2,1,1}
f(3) = {3,1,1}
f(4) = {2,2,1}
f(5) = {5,1,1}
f(6) = {3,2,1}
f(7) = {7,1,1}
f(8) = {2,2,2}
f(9) = {3,3,1}
f(10) = {5,2,1}
f(11) = {11,1,1}
f(12) = {3,2,2}
f(13) = {13,1,1}
f(14) = {7,2,1}
f(15) = {5,3,1}
f(16) = {4,2,2}
f(17) = {17,1,1}
f(18) = {3,3,2}
f(19) = {19,1,1}
f(20) = {5,2,2}
Above, note especially f(8), f(12), f(16), f(18), and f(20).
Any patterns noticed may be productive. A simple example is that, for a prime number p, f(p)={p,1,1}. Another: for a positive integer n, f(n^3)={n,n,n}.
I'm not sure these results are necessarily unique.
Mathematics news on Phys.org
This homework? Anyways, have you tried analyzing the mathematics of the problem yet?
No, it's not homework.
I've managed to reduce it to a problem of combinatorially grouping the prime factors of an integer, but more than that is beyond me (i.e. minimizing the difference between the factors chosen and the cube root of the number)
The other angle of attack I could think of is recursive, with the base case having two cases:
Case 1:
Being one integer: n.
Case 2:
Return: two positive integers {a,b} such that a*b=n, the variance of {a,b} is minimized, and a>=b.
The return might also be understood as "give the (integer) dimensions of the squarest square of area n".
Let a(n) = the least divisor of n greater than or equal to the square root of n
Let b(n) = the greatest divisor of n less than or equal to the square root of n
Then f(n) = {a(n), b(n)}
Is there a recursive relationship?
f(1) = {1,1,1}
f(2) = {2,1,1}
f(3) = {3,1,1}
f(4) = {2,2,1}
f(5) = {5,1,1}
f(6) = {3,2,1}
f(7) = {7,1,1}
f(8) = {2,2,2}
f(9) = {3,3,1}
f(10) = {5,2,1}
f(11) = {11,1,1}
f(12) = {3,2,2}
f(13) = {13,1,1}
f(14) = {7,2,1}
f(15) = {5,3,1}
f(16) = {4,2,2}
f(17) = {17,1,1}
f(18) = {3,3,2}
f(19) = {19,1,1}
f(20) = {5,2,2}
Seems to me that when given a prime number, the first of the three values returned by f is the same number.
Also, when given a perfect square, the first of the three values returned by f is the square root.
Go wild. :)
Sartak said:
f(1) = {1,1,1}
f(2) = {2,1,1}
f(3) = {3,1,1}
f(4) = {2,2,1}
f(5) = {5,1,1}
f(6) = {3,2,1}
f(7) = {7,1,1}
f(8) = {2,2,2}
f(9) = {3,3,1}
f(10) = {5,2,1}
f(11) = {11,1,1}
f(12) = {3,2,2}
f(13) = {13,1,1}
f(14) = {7,2,1}
f(15) = {5,3,1}
f(16) = {4,2,2}
f(17) = {17,1,1}
f(18) = {3,3,2}
f(19) = {19,1,1}
f(20) = {5,2,2}
Go wild. :)
Yep, I noted that in my post :).
Is it not a case of reducing it down into its prime factors and if the number of factors is greater than 3 then attempting to use a variation on the dustbin packing algorithm where you attempt to try and get all 3 slots as close to the cube root of the original number?
If writing up a program to do this that is where I would at least start.
I have a simple algorithm that should work, I think.
Reduce n to its prime factors. If there are less than 3 factors, fill up to three with 1's, if there are exactly 3 factors, use those, if there are more than 3 factors, multiply the smallest two factors, continue multiplying the smallest two factors until you have only 3 factors. Use those.
nevermind, it only works in some cases.
okay, one more try. I think this will work. Maybe.
Find x=n^(1/3). This gives you the side of the cube for the given volume, usually non integer. Then increase x to the first integer that is a factor of n. Then decrease x until you find another factor of n that when multiplied by the first factor you found isn't more than n. The third number will be n divided by these two factors.
doesn't work either ... oh well
Go wild. :)
doesn't work for 64.
Zurtex said:
Is it not a case of reducing it down into its prime factors and if the number of factors is greater than 3 then attempting to use a variation on the dustbin packing algorithm where you attempt to try and get all 3 slots as it close to the cube root of the original number?
What is the dustbin packing algorithm? Is it polynomial in nature?
What are the best algorithms for prime factoring? Are they polynomial (guessing no here)?
Even if I was wrong with how to use it, it really does seem to me that there must be some effecient method starting with the cube root.
There are a few different dustbin-packing algorithms but I don't think any ones that accurately (there are efficient ones that don’t work 100%) work are polynomial in nature. Also of course there are no known factorising algorithms that are polynomial but there are some relatively quick ones these days.
This is really beyond me to work out anything efficient. Have you tried really trying to break the maths down like going of the definition of variance and working out the best way to minimise it?
Sequence
1244
114448
12818176
205090816
_____________
what the following number
  • · Replies 80 ·
11K
  • · Replies 42 ·
12K
  • · Replies 100 ·
13K
  • · Replies 125 ·
21K
  • · Replies 33 ·
9K
  • · Replies 102 ·
12K
  • · Replies 114 ·
13K
