Can You Survive Being Shocked by 120 Volts While Wet?
  • Thread starter nothingman
  • Tags
    Electricity
In summary, electricity is the flow of electric charge through a conductive material and is a form of energy that powers modern devices. It is generated through the use of generators in power plants and can be either AC or DC. AC electricity constantly changes direction and is used in homes and businesses, while DC electricity flows in one direction and is common in batteries and electronic devices. Electricity travels through wires by flowing through a conductive material and is propelled by an electric field. When working with electricity, it is important to take safety precautions such as wearing protective gear and understanding electrical circuits. Never attempt to work on live wires or circuits.
nothingman
OK is it true that you can die if you are wet and are shocked by standard 120 volts?
Like for example if you took a bath and stuck a fork could you die?
btw I touched a 120 volt wire with a wet finger, but it wasn't too bad/fatal...
(is it more likely to die or survive if wet?)
Yep, you can die. Please don't do that.
BTW -- Welcome to the PF. :smile:
nothingman, Welcome to PF! I hope you remain alive for a long, long time and enjoy life. Messing around 120 Volt is HIGHLY dangerous!
WARNING! Electric shocks can kill! Read this Wiki article and NEVER forget to respect ALL electricity.
“Electric shock occurs upon contact of a (human) body with any source of electricity that causes a sufficient current through the skin, muscles, or hair. Typically, the expression is used to denote an unwanted exposure to electricity, hence the effects are considered undesirable.[1]
The minimum current a human can feel depends on the current type (AC or DC) and frequency. A person can feel at least 1 mA (rms) of AC at 60 Hz, while at least 5 mA for DC. The current may, if it is high enough, cause tissue damage or fibrillation which leads to cardiac arrest. 60 mA of AC (rms, 60 Hz) or 300–500 mA of DC can cause fibrillation.[2][3] A sustained electric shock from AC at 120 V, 60 Hz is an especially dangerous source of ventricular fibrillation because it usually exceeds the let-go threshold, while not delivering enough initial energy to propel the person away from the source. However, the potential seriousness of the shock depends on paths through the body that the currents take.[2] Death caused by an electric shock is called electrocution.”
http://en.wikipedia.org/wiki/Electric_shock
The key is that 120 volts CAN kill you, but not necessarily that it will. The best rule of thumb is to simply stay away from any source of electricity.
dry skin is an excellent insulator.
When in my boat in the ocean and covered with salt spray, i cannot touch the 12 volt battery terminal the shock is so severe. That's because the salt water makes skin a lesser insulator so the modest battery voltage gets right through the skin to nerve tissue.
120 volts can definitely kill you when wet.
Your fingertip has thick tough skin on it, don't try that with any other appendages.
So what does that mean that if your finger was a little wet and you accidentally touched an outlet and the water got in you would immediately die? sounds like Scary Stuff.
also btw how do little kids who stick wet fingers in outlets survive?
As already stated, do not play with high voltage electricity, especially if you do not know what you are doing. Thread is locked.
1. What is electricity?
Electricity is the flow of electric charge, typically carried by electrons, through a conductive material. It is a form of energy that powers many of our modern devices and systems.
2. How is electricity generated?
Electricity can be generated in a variety of ways, but the most common method is through the use of generators in power plants. These generators use mechanical energy, such as from steam or falling water, to turn turbines and produce electricity.
3. What is the difference between AC and DC electricity?
AC (alternating current) electricity is the type of electricity that is used to power most homes and businesses. It constantly changes direction, which allows it to travel long distances. DC (direct current) electricity flows in one direction and is commonly used in batteries and electronic devices.
4. How does electricity travel through wires?
Electricity travels through wires by flowing through the conductive material, typically copper or aluminum. The flow of electrons is propelled by an electric field, allowing the electricity to travel from one point to another.
5. What safety precautions should be taken when working with electricity?
Working with electricity can be dangerous, so it is important to take proper safety precautions. This includes wearing protective gear, ensuring all equipment is properly grounded, and following proper procedures for handling and using electricity. It is also important to have a basic understanding of electrical circuits and to never attempt to work on live wires or circuits.
  • Electromagnetism
  • Electromagnetism
80K
  • Other Physics Topics
  • Electrical Engineering
