What Is the Mutual Inductance in a Spark Plug?
The mutual inductance (M) of the primary and secondary coils in a spark plug system can be estimated using the formula M = V / (Imax * f), where V is the voltage supplied by the ignition coil (20kV), Imax is the maximum current in the primary coil (4.0A), and f is the frequency of current interruption (100 times/sec). This results in a calculated mutual inductance of 0.5H. The discussion emphasizes the importance of modeling the current accurately, suggesting a periodic function for I(t) to derive the mutual inductance effectively.
  • Understanding of mutual inductance concepts
  • Familiarity with electromagnetic theory
  • Knowledge of periodic functions and their applications
  • Basic proficiency in using equations related to magnetic flux
  • Study the derivation of mutual inductance in coupled coils
  • Learn about Neumann's equation and its applications in electromagnetism
  • Explore the behavior of current in inductive circuits
  • Investigate the design and function of ignition coils in automotive applications
Students in electrical engineering, physics enthusiasts, and professionals working with ignition systems or electromagnetic devices will benefit from this discussion.
frogjg2003
The ignition coil supplies V=20kV to the spark plugs.
The maximum current in primary coil Imax=4.0A.
The current is interrupted 100 times/sec by the distributor points.
Estimate the mutual inductance M of the primary and secondary coils.
Hint: I have to make a reasonable model of the current I(t).
[itex]\Phi[/itex]1=MI2
[itex]\Phi[/itex]2=MI1
[itex]\Phi[/itex] is the magnetic flux through the coil
I don't think it's necessary, but Neumann's equation might be useful.
I can't visualize what this is supposed to look like. I'm assuming the two coils are coaxial. Are they interwoven? Is one inside of the other? Do they have the same coil density or number of turns?
The other problem I'm having is that I can't decide what a good model function to use for the current.
My best guess would be either a sinusoidal function, or a periodic exponential function.
I think I figured it out.
There was a very short part in the chapter that talked about spark plugs. Right before, it gave the equation:
EMF=-M dI/dt
Assuming that the current has the form:
[itex]I(t)=I_{max}ft, 0≤t≤\frac{1}{f}[/itex]
[itex]I(t+\frac{1}{f})=I(t)[/itex]
Then, ignoring sign, the mutual inductance becomes
[itex]M=\frac{V}{I_{max}f}=0.5H[/itex]
  • · Replies 16 ·
  • · Replies 33 ·
10K
11K
