Derivation of Heat Conduction in Spherical Co-Ordinates
The discussion focuses on deriving the equation for heat conduction in spherical coordinates, specifically addressing the heat flux equation and its transformation into a temperature equation. The derived heat flux equation is dq_{r}/dr + 2/r * q_{r} - \rho H = 0, utilizing Fourier's Law q = -k∇T. The user successfully transitions to the temperature equation (d²T/dr² + 2/r * dT/dr) + ρH/k = 0 and seeks confirmation on the correctness of their integration steps leading to the expression for temperature T = -ρHr²/6k + c₁r + c₂.
  • Understanding of Fourier's Law in heat transfer
  • Knowledge of spherical coordinates and their gradients
  • Familiarity with differential equations and boundary conditions
  • Basic integration techniques in calculus
  • Study the derivation of the Laplacian in spherical coordinates
  • Learn about boundary value problems in heat conduction
  • Explore integration techniques for solving ordinary differential equations
  • Investigate the relationship between Cartesian and spherical coordinate systems in heat transfer
Students and professionals in physics and engineering, particularly those specializing in thermal dynamics and heat transfer analysis.
Tsunoyukami
I have two questions. I believe I have solved the first question and would like confirmation of this answer; the second question I'm a little bit lost on so any help there would be greatly appreciated!
I am working on a problem set in which I must derive the equation for heat conduction in spherical co-ordinates. I have completed part a, in which I derived the heat flux equation:
[itex]\frac{dq_{r}}{dr} + \frac{2}{r}q_{r} - \rho H = 0[/itex]
I have used Fourier's Law (to rewrite this equation for teperature), which states
[itex]\textbf{q}[/itex] = -k[itex]\nabla T[/itex], where [itex]\textbf{q}[/itex] is the heat flux and it is a vector (I couldn't find a vector symbol, so it is simply bolded) and [itex]\nabla[/itex] is the gradient.
Using the gradiant for speherical co-ordinates, and considering only changes in the radial direction (so that [itex]\frac{\delta T}{\delta \phi}[/itex] and [itex]\frac{\delta T}{\delta \theta}[/itex] are 0) we can write:
[itex]\nabla T = \frac{dT}{dr} \widehat{r}[/itex]
So we can write:
[itex]\textbf{q} = q_{r} = -k \nabla T = -k \frac{dT}{dr} \widehat{r}[/itex]
[itex]\frac{d}{dr} ( -k \frac{dT}{dr}) - \frac{2k}{r} \frac{dT}{dr} - \rho H = 0[/itex]
Assuming k is a constant:
[itex]-k \frac{d^{2}T}{dr^{2}} - \frac{2k}{r} \frac{dT}{dr} - \rho H = 0[/itex]
[itex](\frac{d^{2}T}{dr^{2}} + \frac{2}{r} \frac{dT}{dr}) + \frac{\rho H}{k} = 0[/itex]
So I have written this as an equation for temperature instead of heat flux. Is this correct?
____________________________________________________________________________
Next I am asked to solve the above equation for T(r) subject to the boundary conditions T(R) = [itex]T_{s}[/itex] (where R is the radius of the planet) and T(0) must be finite.
Using a hint that is provided I can write:
[itex]\frac{1}{r^{2}} \frac{d}{dr} (r^{2} \frac{dT}{dr}) = - \frac{\rho H}{k}[/itex]
Now, I'm not too sure how to simplify this. My E&M textbook says that the radial component of the Laplacian in spherical co-ordinates is equal to what I have on the left side of that equation so I could write (because we are assuming, as above that [itex]\frac{\delta T}{\delta \phi}[/itex] and [itex]\frac{\delta T}{\delta \theta}[/itex] are 0):
[itex]\nabla^{2}T + \frac{\rho H}{k} = 0[/itex]
What should I do next? Is there any way for me to simplify this further? Should I have not written it in terms of the Laplacian? How can I solve for an expression T(r)?
Thanks in advance! I appreciate any insight you can give me as to what the next step might be! :)
So I've been thinking about this a bit more and I know that this expression must be correct because it agrees with the expression derived in class using Cartesian co-ordinates.
However, I need an expression for T in terms of r and this is where I get stuck.
[itex]\frac{d}{dr} (r^{2} \frac{dT}{dr}) = - \frac{\rho Hr^{2}}{k}[/itex]
We can then integrate both sides with respect to r:
[itex]r^{2} \frac{dT}{dr} = - \frac{\rho Hr^{3}}{3k} + c_{1}[/itex]
[itex]\frac{dT}{dr} = - \frac{\rho Hr}{3k} + c_{1}[/itex]
Integrating again we can write:
[itex]T = - \frac{\rho Hr^{2}}{6k} + c_{1}r + c_{2}[/itex]
Is this correct? I'm concerned that I did something incorrect while integrating the first time; I feel like the 6 shouldn't be in the denominator. In Cartesian co-ordinates we have a 2 in the denominator. Where am I going wrong?
I believe there must be a 2 and not a 6 because if r is solely in the y direction (x and z = 0) the equation should reduce to what we found in the Cartesian case.
  • · Replies 46 ·
  • · Replies 0 ·
  • · Replies 32 ·
