What Is This Mysterious Component on My PCB?
  • Thread starter Thread starter bigshow1977
    Device
The discussion revolves around identifying a mysterious component on a printed circuit board (PCB). Participants explore various hypotheses regarding the nature and function of the component, including its potential as a crystal, programmable oscillator, common mode choke, or transformer. The conversation includes suggestions for further investigation and analysis of the component.
  • Some participants propose that the component may be a crystal, indicated by its labeling (fcc13, fcc14).
  • Others suggest it could be a programmable oscillator, noting that the similar markings imply different programming options.
  • A participant mentions the possibility of finding a schematic or user guide for the board to aid in identification.
  • One participant recommends measuring resistance between output pins to gather more information about the component's function.
  • Another viewpoint suggests that the component might be a common mode choke or transformer, based on its appearance and testing for continuity.
  • There is a discussion about whether the component is a surface mount crystal or an SMT part, with differing opinions on its physical characteristics.
Participants express multiple competing views regarding the identity of the component, with no consensus reached on its exact nature or function.
Some assumptions about the component's function depend on its physical characteristics, which are not definitively established in the discussion. The potential for confusion arises from the component's labeling and appearance, as well as the lack of a schematic.
bigshow1977
Hi
I'm having problems identifying a component on a PCB and i was wondering if anyone here could shed some light on what this device is...
http://db.tt/i1V3uqZf
Anyhelp is appreciated
Rgds
Phil
my guess is its a crystal and the labeling of fcc13 fcc14 ... kind of indicates that
if you know what the board is you might be able to get a schematic online or a user guide.
bigshow1977 said:
Hi
Rgds
Phil
I think you are right about it being a frequency source, but my guess would be a programmable oscillator. Especially since they all have the same overall marking, the difference would be in how they are programmed.
This is a similar part:
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=us&KeyWords=AP3S3EJ-ND
When ordering it from Digikey, you tell them what frequency you want them programmed to. I recently ordered some at 38.4000MHz, and the other was 39.3216MHz.
I think you nailed it. the device looks remarkably similar to the OP's picture.
You could narrow the search a bit by measuring the resistance from each output pin to the other pins on one of these devices.
Draw up a diagram of the resistances, if any, that you find.
Also note how each of those things are connected to each other via the printed circuit board. Do the power supply lines seem to go through all of them?
The FCC bit makes it sound like an interference filter. FCC is the American Govt agency that deals with radio interference, among other things.
bigshow1977 said:
Hi
Rgds
Phil
Looks like a common mode choke or transformer.
Take a multimeter and test for continuity between the pins. If it beeps between any 2 pins it's either a transformer or choke.
@Berkemen, are you sure it's a Surface mount crystal?
The part in the ckt, looks more like a plastic box than a SMD component.
Yeah, looks like an SMT part to me from that view. Kind of similar to an SO-8 package, but with only 4 leads. I could be wrong, of course.
