| New Reply |
why is superdeterminism not the universally accepted explanation of nonlocality? |
Share Thread | Thread Tools |
| Mar5-12, 07:24 PM | #273 |
why is superdeterminism not the universally accepted explanation of nonlocality?Anyway, of course an analysis of entanglement can consist of something other than asking what determines the results of individual detection. It starts with recognizing that the rates of individual and coincidental detection are determined by different parameters. |
| Mar5-12, 07:30 PM | #274 |
| Mar5-12, 07:37 PM | #275 |
| Mar5-12, 07:49 PM | #276 |
| Mar5-12, 08:00 PM | #277 |
@ Joncon and lugita15,
I think this is a case of "not seeing the forest for the trees". There are two different measurement contexts to consider. The results wrt which are determined by different parameters, both measurement and assumed underlying. I'm going to take a time out now. Please reread what I've written. Think about it some more. And I'll get back to you in a few hours. |
| Mar5-12, 08:02 PM | #278 |
| Mar5-12, 08:04 PM | #279 |
| Mar5-12, 08:53 PM | #280 |
Whether coincidental detections are counted 'on the fly' by circuitry built into the experimental design, or after the fact via time stamps, the fact is that the basic datum of entanglement setups (eg., Bell tests) is called coincidental detection, and the rate of coincidental detection varies as a function of θ, the angular difference between the polarizer settings. So, given that the rate of individual detection doesn't vary as a function of polarizer setting, then what can you infer from this? |
| Mar5-12, 09:19 PM | #281 |
| Mar5-12, 09:42 PM | #282 |
And in reply to that you propose an idealized experiment that has nothing to do with what we're talking about. The fact of the matter is that wrt Bell tests there are time stamps, distance measurements, and coincidence intervals. So, you're going to have to deal with them. |
| Mar5-12, 09:48 PM | #283 |
| Mar5-12, 10:12 PM | #284 |
Bell test correlations refers to the correlation between the angular difference between the polarizers and the rate of coincidental detection. Here's what's known. The rate of individual detection doesn't vary with polarizer orientation. The rate of coincidental detection does vary with the angular difference between polarizer orientation. How can these two different experimental contexts be measuring the same underlying parameter? If so, just admit it and then DrC et al. can help you learn about them. They certainly helped me. I'm still more or less quite ignorant ... but a bit less so thanks to their help. |
| Mar5-12, 10:22 PM | #285 |
I've asked you a specific question, that you still haven't answered, about what you would infer from the experimental facts that, wrt Bell tests, the rate of individual detection does not vary as a function of polarizer orientation, while the rate of coincidental detection does vary as a function of the angular difference between polarizer orientations. So, what might you infer from this? |
| Mar5-12, 10:44 PM | #286 |
"All a local determinist might infer from this is that the decision of whether to go through the polarizer or not is based on some local hidden variable, but we human beings don't know the value of this variable, so to us it seems like an unpredictable 50-50 chance whether it will go through." And I'll add that a local determinist would say that the reason a comparison of individual detection results yields a correlation which depends on the relative angle of the polarizers is that both photons contain the same basic hidden variable information, so when we turn our polarizers to different angles we're finding out different parts of this shared information. |
| Mar5-12, 11:56 PM | #287 |
Wrt Bell tests, the rate of individual detection does not vary as a function of polarizer orientation, while the rate of coincidental detection does vary as a function of the angular difference between polarizer orientations. What might you infer from this? |
| Mar6-12, 01:20 AM | #288 |
| Mar6-12, 02:15 AM | #289 |
| New Reply |
| Thread Tools | |
Similar Threads for: why is superdeterminism not the universally accepted explanation of nonlocality?
| Gauss' Law Universally True? | Classical Physics | 36 | ||
| superluminal instantaneous influence | Quantum Physics | 5 | ||
| Arguments Against Superdeterminism | General Discussion | 142 | ||
| why is there such little talk regarding superdeterminism? | General Discussion | 23 | ||
| I hear a lot about nonlocality and it's relationship to QM | Quantum Physics | 3 | ||
