Understanding Forces in Action: Solving a Physics Resolution
  • Thread starter Thread starter EdZ
    Forces
The discussion revolves around understanding the resolution of forces in a physics problem, specifically focusing on how to analyze and verify solutions. The original poster expresses confusion regarding a friend's solution and seeks clarification on the methodology used, as well as guidance on error analysis in equations.
  • Participants discuss the importance of showing where confusion arises in problem-solving. There is an inquiry about the procedure for identifying errors in equations, particularly in the context of error analysis and unit consistency.
The conversation has shifted from the original question about a friend's solution to a more general inquiry about error analysis in equations. Some participants have offered guidance on maintaining unit consistency as a method for checking work, while others are seeking further clarification on these concepts.
Participants are navigating the complexities of physics problem-solving, including the need for clear communication of steps and the importance of units in calculations. There is an acknowledgment of previous discussions about error analysis, indicating a layered understanding of the topic.
EdZ
Hey ppls, how r ya? i have a few questions ...
http://www.boomspeed.com/asianedz/Untitled.jpg
yeh i have the resolution to it although it is my friends one. i dun really understand how he got it... can some1 please explain to me clearly how he did it and if the answer is right?
here are the resolution...
http://www.boomspeed.com/asianedz/Untitled2.jpg
http://www.boomspeed.com/asianedz/Untitledm.jpg
thanks in advance..
EdZ
first show where you got stuck (policy)
then we'll be glad to help
actually forget that one, i read it a few times over again and i understood how to do it.
but i do have one question, i was wondering
what is the procedure to find the error on an equation..
for e.g.
4.7 +- 0.5 * 45.64 +- 0.21 / 32.233 +- 0.923
what are the steps in identifying where the error is.?
The easiest way I've found is to keep the units on your numbers. (I must sound like a broken record... I've said this three times since we switched to the new forums alone)
If you are adding, all summed units must be the same.
All units must also be the same on both side of the equality sign.
sorry, i don't quite understand what your saying... can u please explain again...
sorry, :(
For example,
In your friend's solution for the first problem.
Instead of writing 20-3a=2a
write 20 N - 3kg*a = 2kg*a
You know then, that every term is the same.
It's not a big thing for a simple problem like this, but once you get more things in there, it's an easy way to check yourself.
If the units don't add up on both sides of the equal sign, you've made a mistake.
ahh ok ok... I am with u now... i thought u were talking about my other question which was to do with error analysis...
yes i will keep that in mind.. thankyou!
